Those who replaced the turn signal bulbs with LED ones...
Old Jan 26, 2006 | 01:13 PM
kormax97
People who replaced the front and rear turn signal bulbs with LED 1156 bulbs, what did you do to make it work?
I saw this on ebay to make it work... has anyone tried them? If not what did you do about hyperblinking or not blinking at all?
http://cgi.ebay.com/3-pin-Electronic...QQcmdZViewItem
Old Jan 26, 2006 | 03:19 PM
kormax97
I need some info on this to have LED turns. Anyone? I'm LED challenged.
Old Jan 26, 2006 | 03:21 PM
my1stmax's Avatar
i bought led turn signals and had the same problem. i bought something from the seller V-leds on ebay. its a resistor kit i think. i havent put it in yet, but i think it should work.
Old Jan 26, 2006 | 04:38 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i also wanna put in 1156 LED turn signals in my new diamond clears. I also want amber ones for my new red/clears. But i cant stand the hyperblink. From what i understand you need a resistor. thing is im not sure were it goes. do you need one for each light ? or only one resistor. id assume one for each light to account for the lost load from each filament bulb. whats the correct resistor ohm....ive seen 470ohm. 470K ohms. im sure someone knows im curious myself...oh does the ersistor go on the + or - side of the bulb
Old Jan 27, 2006 | 04:35 PM
YoU CaNt SeE mE
one final bump
Old Jan 27, 2006 | 05:21 PM
White Shadow's Avatar
Still chugging along...
http://www.v-leds.com/ The load resistors that you need and instructions to install them can be found here. Check the FAQ.
Old Jan 28, 2006 | 06:38 PM
PBX's Avatar
PBX
These really any better than regular bulbs?
Old Jan 28, 2006 | 06:51 PM
kormax97
The main reason for me is because I have GEN II for my tail lights and it really goes well with the whole LED theme. Another reason is because I got some LED turn signal bulbs that are purely yellow and not orangish.
03VQMAX
Oct 2, 2016 09:36 AM
220k+ A32
Aug 17, 2015 03:57 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
maxima297
Aug 3, 2015 12:50 PM
