Air Compressor
Old Jan 28, 2006 | 12:29 PM
MistaPeerez's Avatar
Air Compressor
Ok well I'm driving to work and my battery light and brake light turn on. My car is still running so I pull into a parking lot and pop the hood to look and notice that the alternator belt is not there anymore. I then take my car to firestone to have it checked out and they tell me that my A/C compressor locked up causing the belt to snap. They then tell me its going to cost me $1400 to get back on the road. They say that they need to replace the A/C compressor for the alternator belt to work for the alternator to work. Now a friend told me that I could bypass it with a smaller belt to get it to work. But I wasn't sure and haven't gotten another mechanics opinion. I was hoping anyone out there had any experience with my problem or just understand it to give me any advice before I jump $1400 in the hole.. Appreciate the help.
Old Jan 28, 2006 | 01:09 PM
darrick's Avatar
Dallas Nissan Enthusiast
I have had this problem as well it is possible to bypass the Ac compressor I used a gates belt micro v ko60465 not the perfect fit but pretty good if it were 1 inch shorter it would be perfect but it will work well I ran like this for 3 months till I got the parts to repair my ac.
Hope this helps you
-d
Old Jan 28, 2006 | 03:34 PM
bhmax16's Avatar
I'm a mechanic, and will tell you that the above post is correct. You can easily bypass the compressor using a smaller belt, so I would have that done in the meantime and just run without A/C. It's winter anyway $1,400 seems a little high to me though to fix everything. The compressor is VERY easy to change it's only held in by 4 bolts (all easy to get to) and the A/C line. What sucks is the compressor itself I believe is like a $600 to $800 part
Old Jan 30, 2006 | 08:23 AM
Nice. Thanks for the support. I thought this was going to be a pain in the *** but doesnt sound to bad now. Hopefully I can get that belt and get back on the road
Old Jan 30, 2006 | 09:54 AM
98tothemax's Avatar
yes you can bypass it with a shorter belt a new compressor from nissan is 395 dollars took me an hour and a half to install the guy is robbing you for the price even if you funnel out the recharge for the a/c 1400 very expensive or check junk yard 175 dollars
Old Jan 31, 2006 | 11:27 AM
I looked for the gates belt micro v ko60465. I tried finding the product on the net but couldnt find the listing of "60465" anywhere. But found the micro v belts but not that exact one. If anybody can tell me where I can locate this belt would be greatly appreciate it. If on the net or locally. Thanks a lot.
Old Jan 31, 2006 | 11:33 AM
f550maranello2's Avatar
WWW.CAR-PART.COM is all i got to say....
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
