Is it the knock sensor?
Old Jan 30, 2006 | 08:16 AM
tonymich's Avatar
Most of the time my 95 SE (186,000 mi) runs great. Recently the check engine light came on. ECU diagostic showed a bad knock sensor. My car is sputtering and even stalling from time to time. I have a new knock sensor that I will install, but I'm wondering...will replacing the knock sensor take care of the occasional sputtering/stalling??
Old Jan 30, 2006 | 08:33 AM
njmodi's Avatar
Do I get a tax break?
The KS will not set the CEL. Go check and get ALL the codes, then report back.
Old Jan 30, 2006 | 08:58 AM
petemo95se's Avatar
I had similar problems with my 95SE (125K miles). Finally a code was thrown and it said it was the MAF Sensor. Replaced that with a new/old stock from eBay and the car has been rock-solid since. Keep your eye out for a MAF sensor b/c when this fails, it could leave you stranded. Bought mine for $200 (NEW, not used) but I've seen them for as cheap as $75 (NEW not used).
PM
Old Jan 30, 2006 | 08:59 AM
tonymich's Avatar
got the knock sensor code only. 3-4. What do you think?
Old Jan 30, 2006 | 09:05 AM
njmodi's Avatar
Then it's time for a new KS. I still recommend you go to autozone and have them pull the codes.. just in case.
Old Jan 30, 2006 | 09:26 AM
tonymich's Avatar
Does autozone charge for that service?
Also, someone else mentioned the air flow sensor. At one point I got a code for that, but now it doesn't come up. Could that be the reason for the stalling/sputtering?
Old Jan 30, 2006 | 09:48 AM
iceman82's Avatar
no they dont charge
Old Jan 30, 2006 | 10:08 AM
NmexMAX's Avatar
dot dot dot ...
The MAF is porobably the cause of the sputtering.
Old Jan 31, 2006 | 03:56 AM
tonymich's Avatar
After I ret the ECU, the Check engine light went off. Then the car sputtered and the light came on...code says MAF. Thanks for the heads up.
Old Jan 31, 2006 | 08:55 AM
davids's Avatar
My 95 GXE idles rough sometimes. Got knock sensor code. Could it also be massflow sensor?
Old Jan 31, 2006 | 09:01 AM
SoLid97SE's Avatar
i also pulled the KS code, been having trouble starting lately. idle in park or neutral is solid, but once i put it into D the rpm's drop and the car starts vibrating. would the KS alleviate these issues? or am i looking at other problems also? no other codes were pulled.
Old Jan 31, 2006 | 09:22 AM
dgeesaman's Avatar
Maintenance Monster
Don't be in a hurry with the knock sensor job. It's often triggered by another problem code like MAF. Wait until you are getting KS code all by itself - and since it won't set the CEL, that means checking the codes when nothing appears wrong.
Old Jan 31, 2006 | 09:30 AM
boostedka's Avatar
Sounds like a MAF problem
Old Jan 31, 2006 | 09:31 AM
petemo95se's Avatar
When my MAF sensor went bad, the car could NOT stay running when it was exhibiting the problem. I had to blip the throttle CONTINUOUSLY while trying to get the car rolling (5-speed). Once rolling, if I stepped on the gas, it would die, kind of like there's too much gas and/or air. The car was almost undriveable.
Occasionally, before it got worse, I would be cruising at highway speeds and feel an occasional 'miss'. It got my attention but it wasn't continuous.
Hope this helps in terms of symptoms.
Old Feb 1, 2006 | 06:52 AM
tonymich's Avatar
I had this problem for a while. Make sure the air filter is properly seated and that the case is closed tightly. That stopped the shakes for me.
Old Feb 1, 2006 | 12:14 PM
tbergma1's Avatar
I got a 0304 and a 0115 (right bank running lean) and i put the 470k resistor on there and reset the ecu and so far 3 days and no codes. Could it be that the KS was causing the 0115? hmm......
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
