Very Strange Idle Problems
Okay, today I noticed that my idle was going waaaaaay low when comming to a stop. I would be driving at a normal speed and rpms. Around 40 mph and ~2k rpms. I would come to a stop and my rpms would drop past 500 and go down to 250. Then shoot back up to 550. I was afraid of stalling, so I would shove it into N when comming to a stop. This occured under normal brakeing. My subwoofer also cuts out for a second during brakeing.
What can be the cause of this?
I have a 02 10 check engine light:
0210
Diagnostic Trouble Code 0210 points to a problem with the fuel injection system. When the engine management system is running in closed-loop mode the Engine Control Unit (the computer) makes continual adjustments to maintain the air-fuel ratio near the ideal point. To achieve this it relies on signals from many sensors including the Mass Air Flow Sensor and the Oxygen Sensors.
This malfunction is detected when the ECM finds that it cannot properly control the air/fuel mixture, and the mixture is too lean (too much air). DTC 0210 indicates this problem exists on the left bank (the front bank, cylinders 2, 4, and 6). Possible causes include ...
- Intake air leaks
- Front Oxygen Sensor
- one or more fuel injectors on the front bank
- exhaust gas leaks
- incorrect fuel pressure
- lack of fuel
- Mass Air Flow Sensor
Just wanted to know if there is a perticualr problem for my idle problem other than what's listed.
The IACV is clean. Throttle body was cleaned a year or so ago. Don't know what else to list...
0210
- Intake air leaks
- exhaust gas leaks
- lack of fuel
Could very likely be that you need a MAF sensor. I was going to say it could be the IACV valve but since you have changed that it wouldn't be that then.
Check the MAF & your intake to ensure they are connected properly. If it was a problem with exhaust, you would probably throw an EGR code (Exhaust gas recirculation).
If your using a K&N filter some of the oils might have got on the wire. The coating would prevent the MAF Sensor from telling the ECU how much air is coming in. Check the Voltage reading on the MAF sensor and check for oxidation or anything on that wire which would cause the Sensor to operate incorrectly.
Originally Posted by SVI30
Here is a quick way to check the MAF sensor:
1. Engine warm, A/C off, tranny in neutral, no load.
2. Stick a pin in the white wire on the MAF sensor.
3. Hook up a DVM to this pin and ground.
4. At idle voltage should be 1.0-1.7V
5. At 2500RPM should be 1.5-2.1V
If voltage is lower than these values, the MAF is no good.
I just replaced my KS and now I have idle problems. Seems to idle at 400rpm but bounces between 200 & 800. Seems like it will stall but never does.
My research indicates a clogged IACV port in the throttle body. Going to clean that out this w/e and see if it sorts it.
BTW, KS replacement is amazing, what a difference!
97_GXE
20
09-17-2015 08:12 PM
lrb6805
09-17-2015 04:49 PM
