power seat bad
Old Feb 4, 2006 | 11:56 AM
zeeman's Avatar
power seat bad
http://community.webshots.com/myphot...ecurity=aFHHJp
the seat doesnt move up or down when using the switch in red. Does anyknow if i could fix by replacing a motor, fuse, etc OR am i gonna have to get a new seat from another max?
Old Feb 4, 2006 | 12:23 PM
siballiance's Avatar
get another max.
lol....
check the fuses, if no, take a seat apart.
Old Feb 4, 2006 | 12:51 PM
njmodi's Avatar
Do I get a tax break?
If the seat moves in all other directions, then it's not a fuse.
It could be something is obstructing that particular track or a bad motor, connection, etc.
Old Feb 5, 2006 | 11:07 AM
blkmax95se's Avatar
do you hear the motor running when you try to move the switch? i had that problem on my max. i took the seat out. theres a rod that rotates and pushes up on the pan under the seat. the pan cracked where the rod attatches to it so the rod would just move through the pan, so it wouldnt move the seat. what i did was weld the pan wehre it was cracked and now it works fine
Old Feb 5, 2006 | 11:42 AM
zeeman's Avatar
no i dont hear any motor running when that switch is pressed. THe other motor+switchs works just fine.
Either its a broken motor or a lose connector. I hope its the second ...
Old Feb 10, 2006 | 08:53 PM
blkmax95se's Avatar
yeah, those are the only two left, aside from a broken wire. good luck dude
Old Feb 11, 2006 | 03:00 PM
nismos14's Avatar
§è~® f®ÈÄk
Or a FUBAR'd switch.
lowpost99
Oct 26, 2025 06:53 PM
GregL65
Sep 5, 2015 09:37 PM
maximusrising
Sep 4, 2015 06:31 PM
trungg86
Sep 4, 2015 04:58 AM
