brake upgrade question
I have new bembo rotors in stock maxima size is there any way to use the 300z caliper with them on the front? I read somewhere on here that it is possible to use them if you mill the rotor down(3-4mm) around the diameter??. If so how much exactly and are the caliper a direct replacement(bolt on)? What problems have people had with this conversion. I know someone (I think jeff) sells a bracket kit to use 13" rotors but I already have these rotors. where can I get the brake lines needed and what do I need to ask for?
Also what about the rears are there any special problems with the rears like the emergecy brake? and is there a difference between the twin turbo and non turbo (30mm-26mm??) 300zx calipers (front and rear)?
edit.....
I could maybe return the rotors I have (unused) so if anyone has information (I.E. Jeff92 on brackets and lines needed as well as price and shipping time please let me know asap) thank you
edit.....
If you do intend on doing the cobra brake upgrade, I have some rotors if you want to buy them.
With the 300zx conversion, you will need the 300zx rotors which need to be milled down like you said. The calipers will bolt right on without a bracket so you just need the Z calipers, Z rotors, and Z lines. BrianV and blemco has the lines.
I suppose you "might" be able to use the stock rotors with the Z calipers but the Z rotors are much much thicker and it might be offset differently.
Or you can simply buy the brackets from Jeff92se and you can do the cobra conversion with the use of the cobra rotors too
Yes there is. If you want the BBK you need the Turbo (30mm) Calipers. If you just want to use the 300z Rotors then you can use the NonTubro (26mm) Calipers. Also you can not use a stock maxima rotor with any 300z Caliper. They are simply too thin.
ok thanks so I need the 300z rotors (milled) or 13" with kit and the turbo calipers. What about the rear?? can I use the non turbo? and will they just bolt up with the 300z rotors(milled?)
Z has a rear drum assebly, unless you want to conver it to a drum setup, then some good pads and SS lines should do well for the rear.
Clearance will the Z calipers is always an issue.Do you have stock wheels or aftermarket?
yea they all changed to 30mm calipers and aluminun.... which is what u need (30mm) doesnt matter alumin. or iron....goto autozone.....u can get them, for 200 bux a pair powedercoated red....and use urs as a core because there is no way for them to match up part#..................
^Feel and modulation, my friend, feel and modulation. I rode in a Max with the cobra/Z32 upgrade and you can really feel the braking power, even as a passenger. It's f*cking sick.
Plus they don't look half bad..
Originally Posted by EvilSE
no use in upgrading to big bigbrake kit... if already the maxima has a sucky... antilock system... i'd just get some brembo... rotors and slap em on
