Power steering belt without a lift...???
Old Feb 6, 2006 | 10:24 AM
el_muchacho_qc's Avatar
I've change belts on couple of maximas before with only a floorjack but i gotta say i'm having a hard time reaching the first big bolt behind the steering pump of this 95 max. I've tried every wratchet/key, nothing can squeeze in there. Is it actually possible to loosen that damn belt without removing any parts?
Old Feb 6, 2006 | 11:11 AM
Business810's Avatar
Yes, it is possible. No, it is not easy. I hated having to replace and adjust mine. I don't remember what size it is off the top of my head, but for some reason I want to say that the bolt is reverse-threaded, so you have to turn it the opposite way (I might be wrong though, my memory is kinda foggy.) Good luck.
Old Feb 6, 2006 | 12:30 PM
Flava_24/7's Avatar
Boosted Panda
You could just cut the old belt off, and put the new one on the power steering side first, then put the belt 1/4 of the way on the crank side, then turn the crank and slip the belt on the rest of the way.
Old Feb 6, 2006 | 01:03 PM
|Bijan|'s Avatar
UCF Lexus
POSSIBLE but hard to do
Old Feb 6, 2006 | 01:05 PM
Flava_24/7's Avatar
Boosted Panda
Why is it hard to do, thats how I did mine, and others here as well.
Old Feb 6, 2006 | 01:08 PM
Dubbya's Avatar
VK56 Inside
There are 2 parts to loosen for the p/s belt. One is the locking nut (or its a bolt) 12mm I believe. Then there is the reverse threaded bolt (tensioner). I think that one is a 10mm.
Old Feb 6, 2006 | 02:31 PM
njmodi's Avatar
Do I get a tax break?
Actually 3 parts - the two you mention, plus the power steering pump pivot bolt - which is what the OP is referring to.
Old Feb 6, 2006 | 04:23 PM
JwaxMax99's Avatar
A combination wrench fits up there, but its a very tight fit.
Old Feb 7, 2006 | 05:10 AM
Buck96's Avatar
I just made this replacement yesterday
You need a socket wrench about 24"s of extensions a Universal Joint and the 14mm socket to knock out the back bolt.
From underneath on the driver side, go over the y- pipe and mid engine support beam and you'll have no problems loosening the bolt.
The others are very simple as well, 1-12mm wrench and a 12mm socket will knock them out too. You'll be done in 30min, at least I was, once I figured out how to attack the back bolt.
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
markevans999
Oct 25, 2015 08:27 AM
ColdCananda
Sep 20, 2015 10:45 PM
Bluenissan
Sep 20, 2015 08:54 PM
