frame cross member problem
Old Feb 7, 2006 | 02:31 AM
i30krab's Avatar
I discovered the bolts that hold the frame member which in turn hold the front and rear motor mounts are stripped and I must figure a way to fix the problem by welding into the frame or adding a metal plate.
Does anyone on the org have any experience with this type of problem?
I prefer not to use heliocoils! there is another piece called big serts
http://www.timesert.com/html/bigsert.html
I hope there is enough metal left on the welded cylindrical nut inside the frame to use these!!
Any ideas will be appreciated.
I can't put in the new urethane motor mount inserts until I fix this problem
__________________
matts95max
Apr 23, 2025 10:44 AM
Hdnseek
Sep 9, 2015 05:55 AM
boomerbrian
Sep 4, 2015 08:25 AM
