Heat not working correctly on my 1998 SE...help
Recently, the heat stopped working correctly on my 1998 SE. I don't have the climate control, just the standard controls. The problem is, when the car is sitting at idle, the heat doesn't seem to work at all. It will just blow cold, even if the car is warm. After driving for awhile, it will start to work normally, but after sitting at idle again it will stop. The controls seem to be working normally. The fan blows fine, and when I move the temperature slider I can hear it working. Anyone know what the problem might be? The car has 150000 miles on it so I expect some things to break, I'd just like to get this fixed because it's frickin' cold here right now, heh. Thanks for any help.
Originally Posted by 9t8alti
Check your coolant level i have the same problem my coolant gets low because of a leak and my heat does the same thing.
Originally Posted by DrX
That was it. I added some coolant and it's nice and toasty. Thanks for the help.
jerrod99_se-l
08-27-2015 08:27 PM
kirkhilles
08-08-2015 10:53 AM
