clutch drops to the floor
Old Feb 8, 2006 | 05:42 AM
C MAX's Avatar
my cousin has a 98 se and she called and said her clutch went to the floor. the clutch is about 3 months old and she drives like a kitten so what could it be. i suggested to bleed the slave cylinder (does anyone know how to do this) or check replace slave cylinder, any suggestions?.
Old Feb 8, 2006 | 05:45 AM
nupe500's Avatar
Jedi Knight
Have her check under the hood, it could be the Master Cylinder or the Slave Cylinder....the fluid leak will indicate which one it is...looks like she'll be taking it to a shop unless she's handy like that...
Old Feb 8, 2006 | 06:09 AM
C MAX's Avatar
thanks i,ll tell her husband and have him check it. from my experience with the max its usually the slave.
Old Feb 8, 2006 | 06:27 AM
nupe500's Avatar
Jedi Knight
I hear you...I lost a master...and the slave was good...but the only way to tell is to check...best of luck with it..
Old Feb 8, 2006 | 08:16 AM
Ninos_Maxima's Avatar
be the change u want2C
yep its the master/slave cyl... it happend to my friends prelude
Old Feb 8, 2006 | 09:43 AM
Y2KSESteve's Avatar
I lost my slave a couple days ago at about 120k. My pedal didnt sit at the floor but it was sticking about halfway..
Old Feb 8, 2006 | 09:58 AM
cardana24's Avatar
Blown
When I had this problem, I replaced my slave and that did not fix it. After that I did the hose going to the slave and that did fix the problem. Mine also crapped out shortly after doing my clutch.
Old Feb 8, 2006 | 10:08 AM
C MAX's Avatar
thanks guys, it turned out to be just the slave cylinder. we replaced it and the car is back to normal.
maxima-junky
Oct 7, 2015 06:13 PM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
