How to replace camshaft position sensor??
Old Feb 8, 2006 | 04:05 PM
Mymax97's Avatar
Hi
Does anyone know how to replace this sensor or how hard/long it takes?
Old Feb 8, 2006 | 04:46 PM
njmaxseltd's Avatar
1 or 2 10mm bolts and it's out. Shouldn't take more then 5 minutes tops...
Old Feb 8, 2006 | 05:45 PM
dgeesaman's Avatar
Maintenance Monster
1 bolt. Twist and pull on sensor.
Assy is the reverse of disassy.
Dave
Old Feb 8, 2006 | 06:01 PM
Mymax97's Avatar
Hi
ok thanks guys. wheres this sensor at?
Old Feb 8, 2006 | 06:56 PM
MaximaSE96's Avatar
Maxima Owner
look on ur timing cover near where u fill ur windshield washer fluid
Old Feb 8, 2006 | 07:49 PM
Mymax97's Avatar
Hi
just making sure but it wouldnt have gotten relocated b/c of the sc'er would it?
Old Feb 8, 2006 | 07:54 PM
99grnmaxgxe's Avatar
Is there not a sensor plug on your timing chain cover? If not, it might if been relocated.
Old Feb 8, 2006 | 08:24 PM
matty's Avatar
If your car is supercharged, and the crank sensor goes bad, youll need to remose the plate to get the sensor off and replaced. Release tension on the belt, dont loosen the oil drain back, Loosen all the bolts on the plate, bring the plate away from the motor, and have someone reach in there and replace it. Make sure you dont remove the drain back hose or Rip it. Oh and dont forget to remove your chrage pipe as well, and filter
-matt
Old Feb 9, 2006 | 05:48 AM
Mymax97's Avatar
Hi
ok thanks for the information.
AnsonJ
Jun 2, 2017 01:35 PM
Rage Maximus
Sep 3, 2015 12:26 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
wingnut2006
Aug 15, 2015 04:16 PM
