car not starting
Old Feb 8, 2006 | 08:38 PM
SDB318's Avatar
car not starting
hey guys
i have a problem. i went to my car on tuesday morning and my car would not start. it will crank but not turn over. i have a little more than a 1/4 of gas in the tank. just wondering if u guys have any solutions on what it could be.
thanks
scott
Old Feb 8, 2006 | 09:21 PM
zeeman's Avatar
if problem just happened recently and u did not have any CEL light, its prob your batt if its old. I had same prob like urs and i just bought a new batt.
Old Feb 9, 2006 | 04:31 AM
SDB318's Avatar
i thought about that but i just bought a new battery in august
Old Feb 9, 2006 | 07:24 AM
Cjames's Avatar
your key deprogrammed itself.
Old Feb 9, 2006 | 07:42 AM
SDB318's Avatar
how would i reprogram my key?
Old Feb 9, 2006 | 07:49 AM
Cjames's Avatar
nissan dealers can do it, or you can try calling a local place and see if they offer the service. its usually 75 bucks plus.
when you put the key in your ignition, your ignition activates a transponder in your key which omits a frequency that is recognized by your ignition. sometimes the key looses its prorgram, and the ignition will not recognize the key. some people never have trouble, some people do, its really a freak thing when it stops working.
your fuel pump wont work when your ignition doesnt recognize the key. yoru car will turn over but not fire up. many times, the first time you try to crank the car after the key deprograms, the car may start for a second, maybe less... depending on how much fuel was left in the fuel line.
The only way to have it reprogrammed it so have someone do it. the computer to do this project costs in excess of 15,000 dollars and can only be bought by a licensed tech.
Old Feb 9, 2006 | 07:52 AM
Cjames's Avatar
Try some fof these:
Advanced Lock & Security Inc
375 Morgan St, Phoenixville, PA
(610) 415-1330
(610) 489-0893
Dave's Mobile Lock Svc
547 Nutt Rd, Phoenixville, PA
(610) 933-8474
Betalocks
161 Bechtel Rd, Collegeville, PA
(610) 489-3489
Beauregard Ernest
73 N Church St, Spring City, PA
(610) 948-7630
****-Tow
900 Main St, Royersford, PA
(610) 792-9014
Collegeville Lock Shop
334 E Main St, Collegeville, PA
(610) 489-6689
Tom Hood Bonded Locksmith
303 Lauman Ave, Norristown, PA
(610) 539-9555
Maruscak Joseph M
1111 W Bridge St, Spring City, PA
(610) 948-3491
Iffrig's Locksmith
1067 W Lincoln Hwy, Berwyn, PA
(610) 644-1458
Old Feb 9, 2006 | 08:22 AM
SDB318's Avatar
but i dont have a chip in my key. or does this not matter
Old Feb 9, 2006 | 09:09 AM
Cjames's Avatar
ooh, i dont know about the 95's. if you dont have it then you have a different problem. i thought all 4th gens had this key
Old Feb 9, 2006 | 09:21 AM
CRiME's Avatar
oem ftw!
Originally Posted by SDB318
hey guys
thanks
scott
Hate to ask the obvious, but have you tried giving it gas while turning the key. A couple weeks ago, my car started up, and died instantly. After that, it refused to start. I gave it some gas while cranking, and it started up, hasn't done it since then... When this happened to me, i also had about 1/4 tank of gas, and the weather was very cold. I've been keeping it above 1/2 tank ever since then. I thought my Engine Coolant Temp sensor was going bad, but I didn't get that code when I checked my ECU. Do you have any codes? Usually that's the best place to begin. Cleaning the Throttle Body also might not be a bad idea. Additionally, you can give the starter a whack and see if you have any luck.
Also, it couldn't hurt to try jumpstarting the car. I see that you replaced the battery in august, but still, with the cold weather we've been having, it's worth a shot.
Old Feb 9, 2006 | 11:51 AM
SDB318's Avatar
i tried the giving it some gas. no engine light came up.
Old Feb 9, 2006 | 02:58 PM
csb's Avatar
csb
I completely agree with the earlier post re: battery. My gf owns a Volvo S-80 (don't even start) which has been doing the exact...same...thing. We replaced the fuel pump, yet the problem persisted. She eventually brought it to the stealership. The problem??? 29 (yes...29) stored codes and a battery at 15% charge. They cleared the codes and fully charged the battery. Problem gone bye-bye...just my 2.3 cents.
Old Feb 9, 2006 | 03:15 PM
CRiME's Avatar
oem ftw!
The abscence of a CEL doesn't necessarily mean you don't have any stored codes. For example, last week, I checked my ECU out of curiosity ( no CEL ) and lo & behold, I need a new knock sensor. I think the best thing to do would be to manually check.
Old Feb 9, 2006 | 03:25 PM
zeeman's Avatar
maybe its the crank position sensor??
Old Feb 9, 2006 | 07:18 PM
Cjames's Avatar
ive never heard of this battery issue. if you want to clear your codes, just unplug your negative battery cable for an hour or two
Old Feb 10, 2006 | 09:49 AM
mechanicaljoint's Avatar
Very rarely, lately, my 95 SE with 155k will not want to start. The starter cranks away (only 6 mo old)...
sounds like your starter and battery are solid...
What i do is run the starter for about 30 seconds, let it sit for about 2 minutes and do it again, and repeat. After about the 2 or 3rd time it will fire up and run no problem. dont give it any gas...let the ECU do it's job.
when this happens i typically have a pretty pungent exhaust (from my car, not me) which makes me think that the car was originally flooded and just had to "waste" the excess fuel out the back before the right A/F mix was obtained.
crank pos sensor will throw a code if it fouls.
Old Feb 13, 2006 | 11:40 AM
SDB318's Avatar
its in the shop now so we'll see thats up with it
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
