E-brake light stuck on
Old Feb 9, 2006 | 06:23 AM
mendon99's Avatar
tastey wheat
... it doesn't seem like the car is being held back or anything, so it doesn't seem like it a physical issue (like with the brake line vs electrical), but it must be, cus it really only happens when its cold. Anyone else have this problem?
Old Feb 9, 2006 | 06:28 AM
Preet S 22's Avatar
I30"T"
hi,
Im not sure if this is exactly true or not; but someone once told my friend for his 5th gen that his ebrake light was on cuz he needed to replace the brakes....we replaced the brakes and the light never came back.....just a thought.......hope it works out
Old Feb 9, 2006 | 06:33 AM
mendon99's Avatar
tastey wheat
hrm... interesting. last i checked my brakes were fine, but ill check again, sure
Old Feb 9, 2006 | 06:35 AM
Mxrider52's Avatar
I support for what?
Check your brake fluid I had this happen other day and when brake fluid is low the brake light stays on
Old Feb 9, 2006 | 07:07 AM
kil2board's Avatar
i had this happen once before on a really cold morning. check your fluid for the hell of it, and if its at a good level go on a long straight street and go up to atleast 40 and brake hard. not hard enough to leave a skid strip.
If the light is still on, it might be you need new brakes. Mine were done 2 days after this happened.
Old Feb 9, 2006 | 07:48 AM
scrhale's Avatar
Brake fluid levels drop when it is cold. If you look at the resevour or whatever then you will see (hot-high, hot-low, cold-high, cold-low). Since it is getting cold, the levels are out-of-wack I guess. Just drop some of the recommended stuff in the fluid forum and you should be good to go.
Old Feb 9, 2006 | 12:08 PM
pmohr's Avatar
No more Maximas...
Only three things trigger that light.
Parking brake, low fluid, and hydraulic circuit failure.
Diagnosis is easy, keeping that in mind.
Old Feb 9, 2006 | 12:47 PM
VIP Maxima
brake fluid is low which means the pads are out !
Old Feb 9, 2006 | 03:28 PM
njmaxseltd's Avatar
Brake light on, humm, check the air conditioner... yea thats it...
I wonder what you'd check if the low washer fluid light came on?
Oh wait, I know.... that would be the blinkers.
Old Feb 9, 2006 | 09:24 PM
mendon99's Avatar
tastey wheat
thank you for the sarcasim, oh wise OG. i thought the light was only for the ebrake, as i've only seen it come on then.
Old Feb 9, 2006 | 09:32 PM
i30ds's Avatar
Armed and Dangerous
Might be the switch on the actual ebrake under the center console... thats what the problem was on my friends 96.
Old Feb 9, 2006 | 11:20 PM
PFCGlass's Avatar
This happened to me a week ago.. Turned out I was just really low on brake fluid, so it's no big deal. Or it could also mean you need to replace your brakes..
Old Feb 10, 2006 | 12:51 AM
blackbeautyse97
My light came on and I change the front brake pads and the light when off.
mvm062
Nov 30, 2020 09:00 AM
pktaske
May 6, 2016 07:49 AM
Maxima30
Sep 7, 2015 06:13 PM
pktaske
Sep 4, 2015 08:40 AM
A32goldylocks
Sep 2, 2015 06:39 AM
