When Braking Car Pulls to The Right
Old Feb 12, 2006 | 03:23 PM
Trajiksmax's Avatar
Proud Maxima Owner
When I apply moderate pressure on the brakes, the car will pull slightly to the right. (feels like torque steer) I just replaced my brake pads last year with OEM ceramic pads. I had the rotors re-surfaced, and now it pulls. Can anyone give me some good feedback on what could be causing this? Thanks.
Old Feb 12, 2006 | 03:40 PM
wunfstmax's Avatar
It could be a caliper sticking. Does it pulsate at all?
Old Feb 12, 2006 | 04:50 PM
BlackMaxdout's Avatar
My Nissan pickup used to do this (to the right). Upon getting out and inspecting it, I had smoke rolling off the pads and rotor. It was because the pads were too tight around the rotor. To fix it, I took one of the backing shims out. Fixed, and it never gave me a problem since. I also just replaced the rear pads on my Max, and they squeel, can't figure out why.
Old Feb 12, 2006 | 05:07 PM
MDeezy's Avatar
dragging caliper sounds like the culprit.
Pull the caliper off, and test the caliper pins. Regreese, and see if that does the trick.
Old Feb 13, 2006 | 01:33 PM
nismos14's Avatar
§è~® f®ÈÄk
I think a bad or warped rotor can cause it too.
Old Feb 13, 2006 | 03:27 PM
Trajiksmax's Avatar
Proud Maxima Owner
What you mentioned is what I am leaning towards, The passanger side is where they had to cut more than the driver. I watched him while turning the rotor, and I could see a spot that was barely touching the cutter while he was turning it. Time to get some slotted rotors.
Old Feb 13, 2006 | 03:31 PM
MDeezy's Avatar
If warped rotors is the case, he should feel some vibrations as well.
Old Feb 13, 2006 | 08:08 PM
nismos14's Avatar
§è~® f®ÈÄk
Yup but if the rotor was resurfaced wrong that seems like a likely candidate as well.
Old Feb 13, 2006 | 08:42 PM
maximaman10's Avatar
Replace the calipers and reblead the brakes.
Old Feb 13, 2006 | 09:53 PM
DAVE Sz's Avatar
Hooooooonda.....
Make sure the road isn't slanted to the right.
Old Feb 14, 2006 | 08:12 AM
scrhale's Avatar
Sorry to jack the thread but people started mentioning resurfacing. How many times would you guys resurface yours? I have already done it once and am VERY tempted to just throw on Brembo Blanks and shut up.
Thanks for the input.
Old Feb 14, 2006 | 08:34 AM
Tim96I30t's Avatar
Time for a new caliper, start looking
Old Feb 14, 2006 | 10:07 AM
i30ds's Avatar
Armed and Dangerous
Either have a warpped rotor or your caliper slider bolts need to be greased or both.
Old Feb 14, 2006 | 02:19 PM
clive's Avatar
100% chingon
Doesn't make sense. Passenger side is the right, and car pulls to the right. That means that the brakes on the right (passenger) side are working better than the brakes on the left.
Lift the left (driver) side, take the wheel off, and check the pad wear. I'm betting you'll find either
(1) uneven wear (cause: binding caliper pins, as stated by others. dismantle, clean, grease) or
(2) brake fluid leaking on to the pads (cause: bad caliper piston seal. replace caliper or, if broke, try a repair kit)
Old Feb 14, 2006 | 02:52 PM
nismos14's Avatar
§è~® f®ÈÄk
If the passenger side is sticking it makes sense.
Old Feb 14, 2006 | 03:49 PM
clive's Avatar
100% chingon
He said 'pulls to the right', so I assumed that he meant under braking only, not while cruising. Car pulls to the side of the good brake, correct? That's why I suggested checking the one (left) that is working less well.
Old Feb 14, 2006 | 04:18 PM
MaxGordon7's Avatar
my left side caliper sliding pin was rusted into the spot which caused my car to pull left. I had to replace the part that when over the rotor and held the caliper cuz i couldnt free the pin from it. Just something to look at.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
