Front Brakes
Old Feb 13, 2006 | 06:05 AM
fisher01's Avatar
Front Brakes
Just noticed today that the front brake pads are wearing very slowly compared to rear brake pads. I've replaced the front brake pads about 3 years ago and was thinking I'm about due for replacement (have 50,000 miles on them). When i checked the rear brake pads which I replaced about 15,000 miles ago, they were already half worn down. Nissan brake pad front/rear. These are not abs brakes.
I'm thinking a proportional valve problem. Is this valve built in to the master cylinder?
Old Feb 13, 2006 | 07:44 AM
Dubbya's Avatar
VK56 Inside
Im thinking either your emergency brake cable is stuck or your rear calipers are sticking.
Old Feb 13, 2006 | 09:21 AM
fisher01's Avatar
Neither, I replaced the calipers and emergency cables last summer.
Old Feb 13, 2006 | 09:25 AM
MaximaSE96's Avatar
Maxima Owner
ur cable might need adjusting..
Old Feb 13, 2006 | 09:32 AM
MDeezy's Avatar
it could be sticking again. Check the calipers pins and see how freely they move.
Old Feb 13, 2006 | 12:00 PM
nismos14's Avatar
§è~® f®ÈÄk
Sounds like calipers sticking and possibly causing e-brake to not disengage or vice versa.
Old Feb 13, 2006 | 12:24 PM
fisher01's Avatar
I really don't think the calipers or parking brake cable is sticking. Last July, I replaced the calipers, new pins, hardware, pads, etc on both sides. Also ended up replacing the parking park cables. I have the parking brake cable adjusted very loosely. Cable moves freely. The rear wheels move freely no binding at all when jacking up the car. After a long drive, the calipers are not extremely hot. I've been through frozen calipers and binding parking brake cables before and the rear wheels are not displaying those symptoms. Just that the rear pads have lost over 50% wear since July. Thats why I ask about the master cylinder, seems to me the the car is using the rear brakes more than the fronts.
Old Feb 13, 2006 | 02:48 PM
Dubbya's Avatar
VK56 Inside
Are the front and rear pads the same manufacturer and type?
Old Feb 13, 2006 | 02:59 PM
vsamoylov
loosen up the parking brake cable inside the car.
Old Feb 20, 2006 | 07:56 PM
dannydarkman's Avatar
Just changed all my brake pads about a month ago and it's still making a high shrieking noise. Shouldn't it be gone by now?
Old Feb 20, 2006 | 08:58 PM
ManualMaxima's Avatar
5th Gen till she dies!
what pads are you using? i knwo if you are using autozones lifetime warrenty pads or somehting like that they go pretty quickley
Old Feb 20, 2006 | 09:32 PM
zander's Avatar
I hear almost all aftermarket pads are noisey. Most people I have talked to recommend nissan pads. Could the back pads be closer to the rotors then the front pads? Causing you to push the brakes harder to engage the front brakes? This is why I don't do my own brakes. I figure if I mess up on something in the engine the car won't go, if I mess up on the brakes it won't stop, which is a much scarier thing to me.
Old Feb 20, 2006 | 10:07 PM
PLUMMAXSE's Avatar
This is why I don't do my own brakes. I figure if I mess up on something in the engine the car won't go, if I mess up on the brakes it won't stop, which is a much scarier thing to me.[/QUOTE]
Hey, why pay someone to screw up your brakes, when you can do it yourself
Old Feb 21, 2006 | 01:35 AM
Trajiksmax's Avatar
Proud Maxima Owner
The Dual Proportioning Valvle is seperate from the Master Cylinder. I was reading NFSM (Nissan Factory Shop Manual) and it recommends you bleed the brakes. The bleed pattern is Right Rear, Lef Front, Left Rear, Right Front. Just trying to give you other ideas than just the E-brake cable.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
