How much to fix airbags.
Old Feb 13, 2006 | 03:48 PM
97Se5spd's Avatar
Hey guys, my ghetto dealership ripped out the airbag light in my 98 SE. The light was flashing. They told me it was the one in the passenger seat. Which is the one that everyone has problems with. I guess they thought could fool me by taking the light out, a**holes. So how much would it cost to replace the airbag in the seat and have the light fixed?
Old Feb 13, 2006 | 04:05 PM
Max_Out's Avatar
Under the radar
alot... ari bags arent cheap and in a crash even just a fender bender they can cause the car to be totaled. I really dont know an exact price though.
Old Feb 13, 2006 | 04:07 PM
joew's Avatar
in general regular shops will not work on airbags. it's about 1k from the dealer.
Old Feb 13, 2006 | 04:12 PM
MaximaEvolution's Avatar
there is no airbag in the seat on a 98. It's in the dashboard. and if you're somewhat mechanically inclined you can buy them for no more than $400 off ebay WITH THE MODULE (you need it when replacing airbags, otherwise it could blow the new bags).. get a haynes manual and install em yourself.
From what i hear it's not that difficult.
Old Feb 13, 2006 | 04:13 PM
also, forgot to add.. im pretty sure once u replace the bags and module the light should go out (not 100% on that). Seems as though maybe the module is frozen, thus trippin the light.
Old Feb 13, 2006 | 04:35 PM
crazy1eye's Avatar
Yes, there is side air-bags available in the 2 front seats on '98 Max's. My wife has a '98 SE & I have a '98 GLE, both with side air-bags in the seats.
On my wife's SE her light is flashing & it's the pass side air-bag, or the wire that breaks & it needs changing. I believe it's around $350.CDN. I was debating complaining to Nissan about it seeing it's a known problem & they should cover the cost.
Old Feb 13, 2006 | 04:41 PM
hmm.. didnt know that thank you
Old Feb 13, 2006 | 05:02 PM
Geophrum's Avatar
you dont need to replace the air bag, you need to replace the module.. it is an issue with the wires on the module getting pulled or crimped. the new module has longer wires and fixes this problem. there is a TSB on it that isnt in the stickies.. i found it while trouble shooting my car.. local dealership here sells the module for around 350ish or you could buy the air bag for close to $600 but the air bag will not fix this problem. you need the module
Was told that there was a tsb on it but it isnt in the tsb sticky
TSB# ntb000043
NTB00043
If a 1998 or 1999 Maxima has the SRS light flashing, and self-diagnosis indicates either Side Module LH [OPEN] (code DA) or Side Module RH [OPEN] (code 7A), install a SRS side air bag module of the type indicated in the Parts Information section of thisbulletin to resolve this incident. This new side air bag module (with long harness) replaces both the air bag module and the seat sub-harness. See this bulletin for further details.
Part number K8EHM-7L002 Module A
oh and the leather package has the air bags in the 98 max's the standard cloth do not have Side airbags
Old Feb 13, 2006 | 05:31 PM
MaximaSE96's Avatar
Maxima Owner
yes there is....i have them....but yea its the module...luckily i havent had an issue
Old Feb 13, 2006 | 06:33 PM
97Se5spd's Avatar
So basically to fix the module and the light im lookin at say $650?
Old Feb 13, 2006 | 06:38 PM
Geophrum's Avatar
fix the module and then reset the SES light... about $400 total.
Old Feb 13, 2006 | 06:50 PM
97Se5spd's Avatar
Well the light has been ripped out, so I dont know if that is gonna cost anymore. Although I can still see a bit of the light on in the bottom of the Air Bag symbol so hopefully its still in there.
Old Feb 13, 2006 | 06:52 PM
MaximaSE96's Avatar
Maxima Owner
they proll just took the bulb out so all u got to do is take the cluser out and replace the bulb...its quite easy
Old Feb 13, 2006 | 06:55 PM
97Se5spd's Avatar
O god, I hope the dealer will do that for me. I dont feel comfortable messing with the airbag system. I would pay the dealer for everything, although I know its a ripoff but its the best way.
Old Feb 13, 2006 | 07:33 PM
Geophrum's Avatar
i doubt they ripped the socket out.. like maximase96 said they probably just took the bulb out.. if you have the dealer do it.. just make sure they dont screw you.. make sure they dont charge you for stuff that you dont really need... like the air bag itself
bulb may cost like $2.00
Old Feb 13, 2006 | 07:35 PM
vnphantom's Avatar
My 99 max GLE also have the same problem. I did put some electrical tape on the Airbag light. I had it checked at a dealer before: ... $1200 ... they said it's the passenger's side airbag and the rear airbag as well ... [sigh] ...
Old Feb 13, 2006 | 10:14 PM
tavarish's Avatar
fwd gone rwd cr00
my 98 GLE has side air bags in the seat. They're a common pain in the a$$, as they trip the airbag light all the time.
Old Feb 14, 2006 | 06:26 AM
nismos14's Avatar
§è~® f®ÈÄk
Usually at least $1000 at LEAST.
Old Feb 14, 2006 | 02:22 PM
97Se5spd's Avatar
Should I just get the light fixed and not worry about the side unit? I can still pass NY state inspection with the light flashing?
Old Feb 14, 2006 | 03:13 PM
joew's Avatar
i went to a shop for inspection on my girl friend's 240se. the horn did not work and the guy wanted to fail me for it. after a few minutes of talk, the guy passed me for the horn problem. what a d!ck. i never when back to this place. regarding to inspection, i think it depends on the guy who is doing the inspection.
Old Feb 14, 2006 | 04:41 PM
Geophrum's Avatar
usually safty inspections check safty issues on your vehicle... i does depend on the shop and there rules on what they check but wipers, brakes horns airbags and imissions are all safty issues that are set forth by the state you live in.. i would of failed a car if the horn didnt work also.. just like if your wipers dont work or your brakes are bad or shocks are blown.... all a safty issue
Old Feb 14, 2006 | 05:58 PM
joew's Avatar
rules and laws are good but sometimes there are rules that are not good. you should visit large cities like NYC. lots of people use horn to scare, irritate and even lean on the horn like its saying get the f out of my way. please come visit our city and stand on the corner of mid town manhattan. you will see and hear how horns are being used. well, may be a working horn is good, you use it to say get the f out of my way.
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
