Something wierd happend to my car last nite
Old Feb 15, 2006 | 04:59 AM
Me[kk]A's Avatar
i was waiting at an intersection..when all of a sudden all of my lights come on (like when you put the key to the last setting b4 startin) and the car dies..i start it again and put it back into drive..and the minute i do that it dies again so i strt it a 3rd time and put it into 1st gear and she goes..put it in 2nd and she continues..pop into drive and it holds..but the drive is really jerky and sluggish for like 2 mins before it starts to drive almost normally....
WTF!!!????
Old Feb 15, 2006 | 05:08 AM
|Bijan|'s Avatar
UCF Lexus
alternator.................
Old Feb 15, 2006 | 05:10 AM
Me[kk]A's Avatar
are you sure?? my car srtrs with no problems whatsoever..usually when the alt. is going the car cranks like crap..mine is fine
Old Feb 15, 2006 | 05:12 AM
|Bijan|'s Avatar
UCF Lexus
Battery / oil / check engine light came on, and then it died?
Sounds like alternator to me.
Old Feb 15, 2006 | 05:21 AM
Me[kk]A's Avatar
prob is check engine light is on always..i have the drop resistor mod
Old Feb 15, 2006 | 05:23 AM
|Bijan|'s Avatar
UCF Lexus
OMGZ Dr0p r3sist0R!!!
Old Feb 15, 2006 | 06:11 AM
Me[kk]A's Avatar
anyone else have any thoughts?
Old Feb 15, 2006 | 06:33 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
Even though you CEL is always on I would still check the car for codes first.
Old Feb 15, 2006 | 06:51 AM
max95q's Avatar
Possible Engine Coolant temp sensor? Thats what happened to my car. Lights came on out of no where and the car died. I was able to start it back up and drive but here and there it would die. Replaced it and had no problems after that. Go to Autozone to get your codes checked for free. They are going to ask you what year your car is. I see you are a 95 owner, let them know you have an OBD2 connector for code readings in the car. They tried to give me a hassle until I showed them. They felt dumb then.
Old Feb 15, 2006 | 08:40 AM
nismos14's Avatar
§è~® f®ÈÄk
Could be a host of things. Alternator, transmission, misc sensor CAM pos sensor, crank pos sensor. Good luck.
O ya and check codes FIRST.
Old Feb 15, 2006 | 09:04 AM
MaximaSE96's Avatar
Maxima Owner
yea could be any number of those....so like a broken record...check your codes
Old Feb 15, 2006 | 09:33 AM
Me[kk]A's Avatar
a friend actually called me and told me he had the same problem..for him it ended up being a loose wire from the MAF to the wiring harness..when it wiggled out of position his car would die in gear and run like crap..so im gonna check for that.
Old Feb 15, 2006 | 09:53 AM
tikiboom's Avatar
I need an intervention
whatever it is, better fix it before saturday night
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
beboski
Aug 16, 2015 05:23 PM
Balkins
Aug 12, 2015 06:39 AM
