Changing Starter TIPS !!!
Old Feb 19, 2006 | 11:41 PM
  #41
enforcer's Avatar
Originally Posted by 96mAx2fast
I was having some trouble with my starter( at least i think it was my starter). Sometimes it would grind at the initial turn of the key. Sometimes it would grind for about 2 seconds after the car had started. At the end, it just died. When i turn the key it just clicks once. The battery is Brand new and is working perfectly fine.
Well, im getting my new starter from pinnacle nissan tomorrow (thursday). Im thinking about changing it myself. I cant seem to find a detailed write up. I can take off my intake and all that but im alittle scared to mess with the starter. Is it as simple as it looks. Can anyone give me any advice. I saw a write up on how to regrease it but it doesnt tell me exactly how to remove it. Is it bolted on? Screwed on? Is there any special instructions when replacing it? any special aligning that has to take place?
I appreciate all the support. Thanks
DEja(ckin)VU... you want pics.. i will give you pics... read on..
sorry im kindda pissed coz ive been trying to uninstallthe dammn starter and am stuck on 1 bolt.
Same story here with regards to the problem
Old Feb 19, 2006 | 11:42 PM
  #42
enforcer's Avatar
Originally Posted by bobjohnson
Honestly it takes 5mins man..... too easy.
(see post above for instructions.) be sure to disconnect battery.
Bob, mate you are most welcome to come and open the forsaken bolt.. read on.
Old Feb 19, 2006 | 11:44 PM
  #43
enforcer's Avatar
Originally Posted by surfman21
dont listen to any of these goofs who say in can be done in 15min min...no way. Took me about 2 hours but i took my time and it was also frigid out. The big bolt on the starter is a PITA. Grab the biggest breaker bar you can find and just go at it. Good Luck!
you are right on the mark with 2 hours... i got to teh starter in about 15 minutes but rest is .. [beepppp]
Old Feb 19, 2006 | 11:45 PM
  #44
enforcer's Avatar
Originally Posted by Business810
A breaker bar, or cheater bar, is basically just a long handle for your ratchet. It lets you apply more torque to the bolt with less force. I use a nice thick lead pipe that's probably 2 and a half feet long that I slip over the handle of my 1/2" drive ratchet, it makes it a lot easier to break bolts free.
i dont hink im using this breaker bar.... off to google to get more info.
Old Feb 19, 2006 | 11:46 PM
  #45
enforcer's Avatar
are the bolts usually that bad? WD40?!?! What do you think.?
trust me.. ive tried that.. that sob jsut doesnt turn
Old Feb 19, 2006 | 11:48 PM
  #46
enforcer's Avatar
Originally Posted by loverholic
i dont know how well you are with your hands, but it real easy even if you are kinda dumb, it took me less than 30 mins to change mine last week, and i didnt eveen take my short ram intake off, i disconneceted it and pushed it aside, and i just ised a regular 6inch handle rachet............. its only two dumb bolts, just do what they guys say and spray it first to be on the safe and easy side....peice-a-cake
im a dumb cow then
Old Feb 19, 2006 | 11:50 PM
  #47
enforcer's Avatar
Guys, thank you very much for all your support. I took care of it. I received my new one from pinnacle nissan and replaced it in about 1.5 hours. I could not take the big (11/16) bolt off. I broke my ratchet in half. I had to turn the house upside down at 11:30 at night to find another one. I found it and continued to work on it. It wouldnt come off. I sprayed PB blaster and let it sink in for about 15-20 minutes.. I finally got it off.. i changed it with no problem. Unfortunately, the car has been sitting there for about 2 weeks dead!!! We got like 24" of snow.. when i put the starter, the battery was dead.. i jumped it with my other car (accord coupe v6).. when i went to turn it on, it cranked for about 45 seconds because it has been sitting there for so long.. i took it for a spin and when i came back, i shut it off and turned it back on.. wow, it sounds like a brand new car.. it starts up in about 1/2 a second.. im very happy... thanks again for all the help!!!!!!!!
PS: my check engine light is on and i have no clue why..i plugged everything back.. I gotta check that out next.. stay tuned for the next adventure..
good on ya..
Old Feb 19, 2006 | 11:51 PM
  #48
enforcer's Avatar
Originally Posted by renatonetmail
I pulled my starter out, cleaned it, regreased it, put it back in and problem solved.
tats my intensions if only i could loosen the 2nd bolt
Old Feb 20, 2006 | 12:00 AM
  #49
enforcer's Avatar
Okay this is what im ranting about:
The first bolt was a ****, but ive been on the 2nd one for about 2+ days. Spending 1-1.5 hours each day .
I'm a freekin powerlifter and this dammn thing wont budge. Yes, i've tried WD40 (well i didnt earlier but tonight i've given it a good bath in it), have a look at the pics and Please dont give up on me ... coz im |this| close to a breakdown.... i miss my ride
Using Rachet:
Using IDontKnowWha****Called:
Using WD40:
Using Hammer:
Please HELP!!!!!
Old Feb 20, 2006 | 12:47 AM
  #50
Donald199's Avatar
do what u did in the second pic but with a longer/breaker bar will take it right off.
as of the bracket that`s blocking the second bolt, BENT it upward to loosen the bolt. and bent it back down after ur done.
Old Feb 20, 2006 | 06:44 AM
  #51
Batxel's Avatar
blah
yea, get a breaker bar at least 2' long and call it a day.
Also, make sure you're using the correct size socket cuz your rounding the tranny - engine bolt down pretty bad. You should probably get a new one when you get a chance.
Old Feb 20, 2006 | 09:31 AM
  #52
enforcer's Avatar
hi dude, whcih bracket are you refering to?
I have alonger bar but its difficult to fit it. Will give it a go this evening , i really hope it works
Old Feb 20, 2006 | 09:32 AM
  #53
enforcer's Avatar
Hmm i will try that.. there is not enough space there for 2"... but i will have a look.
oh the rounding of the bolt was coz i hammered it. yea.. will probably get a new bolt once "it" opens up.
cheers.
Old Feb 20, 2006 | 09:38 AM
  #54
tavarish's Avatar
fwd gone rwd cr00
do you have a long metal pipe? if you do, just put it over your ratchet (the second pic, the first pic is a wrench), and pull. It's easier than you think, and requires little effort. I dont have a breaker bar, i just used a pipe and a regular ratchet.
Old Feb 20, 2006 | 12:11 PM
  #55
enforcer's Avatar
Tavarish, thanks for making it clearer. I was making a mistake there.. thinking to myself about how to fit 2" to the bolt. But its the ratchet handle you guys are refering to -- correct?
I will arrange for a longer handle or get a pipe.
Thanks guys...really appreciate it.
will let you know this evening.
Old Feb 23, 2006 | 01:46 AM
  #56
enforcer's Avatar
woohoo... I finally managed to get the starter off the engine.
Quite easy once i figured out the tool required.
i didnt have the Breaker bar or a pipe so guess what i used.... Old Vaccum Cleaner Extension. It was a perfect fit, adn it took about 10 seconds of effort to turn the screw loose.
Cant believe i spent so much time on it .. but hey i got it done - didnt I?
Thanks for all the help .. i will start another thread about the starter A-Z with pics etc.
ciao.
Excalibur23
Oct 13, 2015 04:33 PM
homewrecker
Sep 23, 2015 03:41 AM
dcam0326
Sep 18, 2015 04:52 PM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
