TPS testing and replacement(can't drive car now)
Old Feb 20, 2006 | 07:15 PM
Hunter11's Avatar
I have had escalading problems with my idle. It started in a parking lot just sputtering and it died and I was like WTF. But now my car will die at red lights and while I am making turns, it will cut off b/c I don't have my foot on the gas. It bucks going down the road but sometimes it will run fine. But, it has been getting worse. I can't drive it anymore. It is just to aggrevating and unsafe.
Unless I discover something else I beleive it to be my trottle position sensor.
I have multimeter I bought and the plug itself test fine, 5 volts.
The TPS tested fine with the correct resistance w/ closed and full throttle.
The problem was with the wide open/closed throttle switch. It showed no resistance in the test. Haynes says to check for continuity. I am alittle unclear on this part but I showed no ohms. Is this correct?
I am getting frustrated with this. Has anyone had these problems and replaced the TPS and their car run fine?
Also, I went to the dealership and they want $160 for a new TPS. Any suggestions on where to find an better price?
Old Feb 20, 2006 | 07:40 PM
f550maranello2's Avatar
uhh first of all you supposed to adjust the tps sensor look at the stickies.. plus you can get a tps sensor from autozone for 65 dollars
Old Feb 20, 2006 | 08:05 PM
svetlin55's Avatar
could be dirty MAF,bad ECTS,bad grounds-two ground lugs on IM!
Old Feb 20, 2006 | 08:31 PM
Hunter11's Avatar
The first part of the answer I don't get. I checked the stickies and didn't see anything about adjusting the TPS. My TPS doesn't look like it could be adjusted.
But the last part of your answer, thanks, I could have sworn I checked there but maybe I missed it.
Thanks for the replies....
Old Feb 20, 2006 | 08:41 PM
look on google you supposed to adjust the tps i dont remember what it is.. make sure you do it cuz if you dont ur car will run like crap...
Old Feb 20, 2006 | 08:53 PM
konak85's Avatar
this might help
http://vbxmaxima.8m.com/tps.html
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
schmellyfart
Sep 25, 2015 04:47 PM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
