low idle
Old Feb 22, 2006 | 08:00 AM
SDB318's Avatar
low idle
hey guys
my 95 max has been really low at idle. it is at 400 rpms. i was at 750-800 rpms. just wondering if anybody knows how to fix this.
thanks
scott
Old Feb 22, 2006 | 08:34 AM
Ridge Runner's Avatar
I had a similar issue that I hope is fixed. In the stickies there are write-ups on adjusting idle speed, checking the throttle position sensor (TPS) and cleaning the IAC valve. I did all three, in this order:
- pulled off and cleaned IAC. There was some black and brown crud on it, and a scary amount of the same visible inside the intake plenum.
- checked the TPS voltage and resistance (all good).
- adjusted the idle speed screw with the TPS disconnected. I think this was the actual fix.
I had recently pulled off the air intake, throttle body, and intake plenum, and something must have moved when I reinstalled everything.
Old Feb 22, 2006 | 04:57 PM
nabeel19's Avatar
Also check Throttle Body. Dirtly throttle bidy means - less air = low rmps. Clean it, there is a sticky in the How To's section, and then adjust the idle with the idle screw on IACV valve
Old Feb 22, 2006 | 06:23 PM
SDB318's Avatar
where is the idle screw?
Old Feb 22, 2006 | 07:56 PM
RockfordMax's Avatar
Back from the dead
To the right of the hose coming off the intake tubing. Looks like this
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
