need some help trying to figure out what is wrong
Old Feb 26, 2006 | 08:55 AM
bmiller95max's Avatar
ok...im not sure what this could be, and any help would be great! when i accelerate normally, its extremely sluggish and i need to push about half of the gas pedal down to just normally accelerate. when i slam it almost to the floor, it finally gives it a good amount of gas and pickup, and when im crusing, it feels like it wants to downshift and feels like it will stall, but never does. anyone know or have the slightest idea what this could be???
Old Feb 26, 2006 | 09:55 AM
could it be the ks?
Old Feb 26, 2006 | 10:05 AM
the_3d_man's Avatar
Why don't you go check for codes...
It will tell you if it's the KS (or something else possibly)
by the way...
http://forums.maxima.org/showthread.php?t=104931
just in case you were gonna ask how to pull codes...
Old Feb 26, 2006 | 10:15 AM
95mtlMAXSE's Avatar
shift_Puff
try reseting the ecu before freaking out....sometimes it kinda gives the sensor a kick in the ***...there is a turn screw on the ecu that you can turn to reset the ecu...95-98 only. or just unplug the batt for 30 min and try again...reseting the ecu steps are fairly easy...just keep ignition on, turn scres counterclock wise all the way till it stops(go lightly till u feel something stopping), hold for 2 sec then all the wayclock wise and hold for 2 seconds. Shut off ignition and then start car...it should work...by the way, the screw is right on the right of the gas pedal, remove the plastic cove and you'll see the car's computer with screw behind a clear plastic...good luck
Old Feb 26, 2006 | 10:26 AM
alright thanks guys...ill go try that
Old Feb 26, 2006 | 12:17 PM
the_3d_man's Avatar
ok.... check for codes... don't just reset the ecu...
refer to the link in my first post...
Old Feb 26, 2006 | 06:57 PM
cleanmax's Avatar
i think it could be a couple of things the knock sensor, bad coil or spark plugs, also check your throttle cable and make sure thats its not really loose.
Old Feb 26, 2006 | 07:36 PM
Blackwind's Avatar
vacum leak.
Old Feb 27, 2006 | 10:37 AM
how would i check if its a vacuum leak?
Old Feb 27, 2006 | 08:20 PM
the_3d_man's Avatar
did you ever look for codes?... seriously...
also ... try getting under your hood and listening for a vacuum leak, rev the engine and listen. check vacuum hoses. become familiar with the car!
Old Feb 28, 2006 | 07:01 AM
Blackwind's Avatar
there is your answer.
Old Feb 28, 2006 | 08:52 AM
s0ber's Avatar
You might not hear a vacuum leak if you rev the car, you usally hear those more at idle since thats when the car is drawing the most vacuum.
I suggest spraying around everywhere that could be a possible vacuum leak with carb cleaner or tb cleaner or something like that and if the engine dies down a bit while your spraying you have found your vacuum leak.
Old Feb 28, 2006 | 08:35 PM
ok will try guys, thanks for your help!!
Old Mar 1, 2006 | 05:46 AM
Black Maxima
Where are the vacuum hoses located?
Old Mar 1, 2006 | 02:14 PM
Blackwind's Avatar
under the hood on the engine.
Old Mar 1, 2006 | 03:30 PM
the_3d_man's Avatar
so ... did you check codes?...
Forge277
Jun 13, 2016 09:26 PM
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
