Engine grounding(useless thread)
Old Feb 28, 2006 | 08:35 AM
zander's Avatar
I haven't seen one of these threads in a while so I thought it would be ok to post it. And since I don't have a digital camera I have been reluctant, but here goes. I recently cleaned my gounds and added some gounds to my engine. If you have an auto that likes to hesitate this may help you. My car would always start in 2nd maybe 3rd if I did a rolling stop, it almost totally eliminated this. The car drives solid, no gains per se, but instead of having good and bad days, i just have good days now
Old Feb 28, 2006 | 10:48 AM
mindlessoath's Avatar
i would also like to find out if people who tried tried this did it with a paradox (or other brand) pully? for the lack of annother word that escapes me.
i would also like to add a grounding kit, cause i know it would help out. but to waste money on an aftermarket one is BS... to expensive, just make your own guys!
annother ...
what way would you guys rought your wires? here is how i would do it... wire from negitive to a ground point, from that point to annother point and so on.
most aftermarket kits all go from center out to differnt points, i dont like it, but which way is better? i would guess they are both simular if not the same, but just want to get opinions.
Old Feb 28, 2006 | 10:57 AM
ajcool2's Avatar
I actually ordered my grounding kit last week and should have it soon. As far as how to run them I'm going to find some diagrams and see which one seems the best.
Old Feb 28, 2006 | 11:00 AM
zander's Avatar
Well I got about 6-7 feet of 4 gauge from my work and some gold audio eyelets from pep boys. And since I didn't have a crimper I had to buy one of those. Total was about 30 bucks.
I ran from the drivers side strut tower to the neg battery terminal. If you follow the stock ground from the negative terminal to the engine block this is where I stared my second run from the engine block to the IM, I used a bolt that hold the bracket for TB cables. Then I ran from that bolt to the timing cover, another bracked bolt, and then from the timing cover to the passenger side strut tower. I know there are more grounds I could have done. But I think the stock grounds for alternator ect are good enough if you clean them.
Old Feb 28, 2006 | 11:34 AM
xxtavixx's Avatar
Here are some tips-
When grounding, you MUST scratch the paint off of the location you are grounding too.
You should have at least one ground on the following-
Block
Head
Starter
Alternator
Transmission
AC
Now, sometimes they are incorporated into the wiring harness (alternator, a/c, starter) somtimes they are not.
Old Feb 28, 2006 | 11:39 AM
rsly33's Avatar
Originally Posted by zander
If you have an auto that likes to hesitated this may help you.
This was the only thing I noticed from installing mine too.
Old Feb 28, 2006 | 11:46 AM
zander's Avatar
But the auto going when I want it to is more then worth it to me. No more push the gas and let the car decide if it wants to go today.
Old Feb 28, 2006 | 12:15 PM
aih98max's Avatar
scoobystoned...
is it hard to install a grounding kit? would it eliminate turn on thump from my 1000 watt amp?
Old Feb 28, 2006 | 01:31 PM
clive's Avatar
100% chingon
No. and, No.
Old Feb 28, 2006 | 01:34 PM
Black Maxima
Someone please post a link to a grounding kit diagram...
Old Feb 28, 2006 | 01:57 PM
aih98max's Avatar
scoobystoned...
good idea, Black Maxima
Old Feb 28, 2006 | 03:12 PM
Black Maxima
BUMP Frodo and I are waiting...........................
Old Feb 28, 2006 | 03:35 PM
White Shadow's Avatar
Still chugging along...
Here's one way to do it: http://www.cardomain.com/ride/442543/16
Old Feb 28, 2006 | 03:38 PM
happyricefob's Avatar
V^___^V
i have hks grounding kit and my throttle response + idle improved
Old Feb 28, 2006 | 03:40 PM
V^___^V
dude ur car has like same setup as mine... looks good man
Old Feb 28, 2006 | 03:52 PM
Black Maxima
Thanks for the niiiiiiiiiiiiiiiice grounding link. Is there anything more simple than that? I'm not looking for wires all over my engine bay like that, unless I have to.
happyricefob - Thank you, I like your car too.
Old Feb 28, 2006 | 08:32 PM
I used 4 AWG when I did it in another Nissan car. I replaced the factory ground that goes to the chassis and then the front of the engine block. I put a wire from the chassis to a bolt on the transmission on both sides of the engine bay. One from the alternator to the body. Two more one form the engine block to the chassis on both sides and one form the head to the chassis. Most of these are very short, the shorter the better. Overkill? Probably. Did it work well? No doubt. I also ran a second positive cable (0 AWG) from the battery to the alternator, no need to disconnect the one already in place.
pktaske
May 6, 2016 07:49 AM
6spd4dsc
Mar 4, 2016 05:19 PM
03VQMAX
Sep 5, 2015 03:47 PM
pktaske
Sep 4, 2015 08:40 AM
TheMafia
Sep 4, 2015 08:26 AM
