Throttle Body Question
Old Feb 28, 2006 | 02:20 PM
Frank_Askew's Avatar
Throttle Body Question - Now with PIC
I recently bought a TB from a member here and it has a TPS with 2 connections and not one like my current one. My current one is sticking and other problems including the TPS. I wanted this one because it was a TB that did not stick and came with a working TPS. Can I use this one or am I stuck with a TPS that I can not use.
I have a 1995 5sp and the TB I got came off a 1996 5sp.
Thanks!
Frank
Old Feb 28, 2006 | 03:07 PM
Trajiksmax's Avatar
Proud Maxima Owner
Old Feb 28, 2006 | 05:56 PM
Added Picture - Added Better Picture
Old Feb 28, 2006 | 08:26 PM
I have searched and still no answer to my question, I am asking the community to help me out here, someone has to know why they are different.
Thanks!
Frank
Old Feb 28, 2006 | 08:35 PM
BigLou93SE's Avatar
What does your original look like? That's howmy TPS looks.
Old Feb 28, 2006 | 09:08 PM
my TPS has only 1 connection, like the PIC below.
Old Mar 1, 2006 | 01:33 AM
Trajiksmax's Avatar
Proud Maxima Owner
I looked in the Factory Service Manual, all models 1995-1999 have the TPS which is the bottom terminal on your original post. The other terminal, the top one is the wide open/close throttle switch. I'm still confused on why yours only has one terminal, I think that Nissan made some models with no wide open/close throttle switch. I will look in to this and get back to you.
Old Mar 1, 2006 | 02:53 AM
MaxedOutR34's Avatar
mine was the same way with the one plug. it was because early 95 maximas were obd 1 emissions and later 95's were obd 2 setups. I have a tps with the one connection if you are interested. PM me
Old Mar 1, 2006 | 08:19 PM
DJ98MAXSE's Avatar
My 98 has the same TB as your picture. If your 95 doesn't have that same one you will probably have to source one from a 95. Check Ebay.
Old Mar 2, 2006 | 08:16 AM
clive's Avatar
100% chingon
Why don't you just try it (connecting to the potentiometer part instead of the WOT switch part) and see if it works?
Old Mar 2, 2006 | 08:28 AM
SPiG's Avatar
SomePsychoGuy
My 95 only has one TPS connector and I would assume all 95s only have one. You can probably still use the 96+ TPS and just leave on connector unplugged.
95s are ODBII, the connector is on the passenger floorboard. However cars were not required to be until 96, so 95 Maximas are 1/2 way. 95s do not have all of the sensors, but you can hook up a ODBII unit to it.
Old Mar 2, 2006 | 08:34 AM
JClaw's Avatar
My 95 also has only one connector. It rolled out of the factory on December 20th, 1994, so it's a pretty late 95.
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
Sep 15, 2015 06:47 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
