Battery died and now dc is stuck in player and cd player wont work
Old Mar 1, 2006 | 12:54 PM
lokobreed's Avatar
Ok my battery died. When I jumped it the radio worked but the cd in the player will not be ejcted or can I listen to it.
A freind of mine said I need a code because it has an antitheft system... is this true? if so how do I get the code?
Old Mar 1, 2006 | 12:58 PM
RA030726's Avatar
I'm nutty for Nissans
no code, but you need to manually remove the disc. the same thing happened to me so i took it apart and slid the cd out. you may be able to stick some pliers in there (well something thin) and pull the cd out.
Old Mar 1, 2006 | 01:01 PM
BlackMaxdout's Avatar
I've disconnected my battery plenty of times to work on assorted electrical stuff, and I always had a CD in it. To solve this, I hit eject, and a few days later the CD would usually randomly eject itself. Get an mp3 and AUX audio, problem solved.
Old Mar 1, 2006 | 01:06 PM
Trajiksmax's Avatar
Proud Maxima Owner
Check to see if your radio has a small reset button. (usually the size of a ball point pen tip).
Old Mar 1, 2006 | 06:45 PM
Supermax95's Avatar
try resetting the cd player.....easy way to do this would be to disconnect the battery...
Old Mar 1, 2006 | 10:03 PM
darklegend06's Avatar
wow every time I disconnect the battery and reconnected it ejects on it own. What kind of HU do you have. If you don't want to mess up the cd don't stick anything thin or pliers to pull it out.
Old Mar 1, 2006 | 10:21 PM
rsly33's Avatar
Works for me every time a cd gets stuck
Old Mar 2, 2006 | 06:55 AM
lokobreed's Avatar
I tried sticking tweezers in from the front but I could not even grip the cd and hope I did not harm anything.
How do I disconnect the battery and is it hard to re connect it? and when I reconnedt it should it eject or when I disconnect it should it eject?>
Old Mar 2, 2006 | 07:16 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
[QUOTE=lokobreed]
Dear god...
Old Mar 2, 2006 | 07:36 AM
clive's Avatar
100% chingon
Battery eject mechanisms are not standard on Maximas.
Old Mar 2, 2006 | 08:07 AM
Supermax95's Avatar
remove the positive terminal cord from the battery(should be red) you will probably need some kind of wrench/rachet, wait a couple of seconds and them put it back on....this resets the memory on the stereo and the eject button might work after you REconnect the battery
Old Mar 2, 2006 | 08:12 AM
mbandi's Avatar
Da'Burgh, Go Stillers!
LOL-- Too Funny
Old Mar 2, 2006 | 10:20 AM
Supermax95's Avatar
actually the 99.5 sel's had that standard with the option of a parachute for safe landing.....
CorollaULEV
30
Aug 9, 2021 08:11 PM
Rage Maximus
Sep 3, 2015 12:26 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
305head
Aug 26, 2015 09:03 PM
kenc15
Aug 5, 2015 08:29 AM
