testing MAF
Old Mar 1, 2006 | 02:06 PM
acidspit86's Avatar
testing MAF
how do i test my mass airflow sensor?
Old Mar 1, 2006 | 02:40 PM
RA030726's Avatar
I'm nutty for Nissans
back probe the black and white wires with a multi meter. you need to drive the car and watch the voltage. it will be between 1-5 volts depending on throttle position and load.
Mine is 1.11 at idle and peaks to 4.24 under full throttle.
Old Mar 1, 2006 | 03:29 PM
goldtooth's Avatar
wait wait wait,,,, 1-5 volts??
most others Ive read have .4 volts idle (close) and 4volts WOT....
interesting....
does it matter?
EDIT: Indeed, it is the TPS, my fault.
Old Mar 1, 2006 | 03:35 PM
MaxGordon7's Avatar
that sounds like TPS .4 closed to 4 volts open.
Old Mar 1, 2006 | 06:22 PM
RA030726's Avatar
yes is does matter, since the lower the voltage means the engine sees less air, even tho it would be getting plenty. that means you become lean (well under open loop).
TallTom
57
Oct 14, 2025 05:16 PM
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
