Bose Stereo blinking
I'll be a nice guy and post about it...even though this topic comes up EVERY DAY
there are resistors cracked on a certain PCB board inside the Bose. Look in the "How To" stickies on how to fix it. I fixed mine following the website, and it works perfectly now. Some of the resistors on the board have cracked solder, and depending on vibrations or hot/cold expansion and contraction, you will either get a display or no display.
Originally Posted by gassian
For some reason my stock stereo lights are like blinking and going off and on...
And after i touch the face it comes back....
any ideas what the reason could be??
thanks in advance
thanks in advance
This is the page with info about possible fixes. Seems like you can fix it by re soldering or replacing a resistor: http://Madchef.5u.com/Maxima/Bose/Bose.html
thanks in advance
thanks in advance
The 4 screws on the side frame are pretty tough to get out. You need to lay the HU on the side screw facing up. Then use as large of a screw driver as you have and they will come out. You have need to tap the driver with a hammer as you twist.
I have had this problem a while back. The flickering lights annoyed me so much i knocked the radio really hard with my knuckles. Surprisingly it stopped the flickering! Wierd... i dont recomend abusing or hitting your radio LOL i was just annoyed with mine.
When the lights flicker does the music stop or interrupt? If it does perhaps the power supply , wiring for the power, or fuse has an issue to be fixed.
Gluck!
Gluck!
Might be a resistor like the above posts mentions. If you are willing to fix it yourself go ahead might be a pain or just leave it. I would just go to the scrap yard and buy an identical or higher model from a newer year at good price.
worldwiderecognized
09-30-2015 02:16 PM
