i really need help on solving these ecu codes...
02 01
03 04
I've been getting these occasionally, and they've always been these two. Usually, the check engine light comes on when i drive the car a little hard (4000rpm+, but not over 5200rpm)
does anyone have a solution to what could be wrong? am i going to have to take it to the dealer...again?
03 04
you can go here to read the codes.. http://vbxmaxima.8m.com/ecudecoder.html .. those 2 mean Ignition Signal Circuit .. and Knock Sensor .. what kind of gas are you using.. mayeb with the high revving the gas pings, or something.. im not too sure...just my input
DTC 0201
Originally posted by Ch12i5
02 01
03 04
02 01
03 04
The malfunction is detected when the ignition signal in the primary circuit is not entered during engine cranking or running.
The items to check include
- Harness or connectors (the ignition primary circuit is open or shorted.)
- Power transistor unit built into ignition coil
- Condenser
- Crankshaft Position Sensor (REF)
- Crankshaft Position Sensor (REF) circuit
I would have expected to see DTC 0201 along with other DTCs. Were there any others? A misfire on any individual cylinder should set a code, and a problem with the CPS should also set a code.
You may get one or more of the following DTCs:
0407 - Crankshaft Position Sensor (REF)
0608 - Cylinder 1 misfire
0607 - Cylinder 2 misfire
0606 - Cylinder 3 misfire
0605 - Cylinder 4 misfire
0604 - Cylinder 5 misfire
0603 - Cylinder 6 misfire
DTC 0304
02 01
03 04
02 01
03 04
This malfunction is detected when an excessively high or low voltage from the KS is entered to the ECM. Possible causes include...
- the harness or connector (The KS circuit is open or shorted).
- the KS
The KS may be checked with an ohmmeter.
1) Raise the hood. View the engine from the driver's fender. Look into
the deep valley between the cylinder banks and below the intake manifold.
Identify the KS as a black item fastened to the block by a single vertical
bolt. A wire harness wrapped in black leads toward you, out of the valley.
That is the KS sub-harness.
2) Follow the KS sub-harness to it's nearest connector. This is connector F121.
It is located near the upper right-hand corner of the valve cover of the forward cylinder bank, as viewed from the front of the car.
3) Disconnect F121. You have to do a "press the latch and wiggle and
pull" to disconnect it. F121 has only two pins; if you see more than two
pins, you have the wrong connector. Use a digital ohmmeter capable of
measuring more than 10 Megohms. You want to measure the pins of F121, not
the sockets of the matching connector. Measure the resistance between a
good ground (such as the battery negative terminal) and pin #2 of connector
F121. On my car this is the highest of the two pins, the one closest to
the front of the car. The factory spec is 500 - 620 Kohms.
The manual says you have to remove the intake manifold to replace the KS. However, I think that a person with good dexterity and a 10mm ratcheting box wrench could replace the KS without disturbing the manifold.
Important note: the dealer can do a more thorough test with his CONSULT electronic tester. The resistance test described here is a useful but limited test. A Knock Sensor which passes this test is not guaranteed to be good. However, a Knock Sensor which fails this test is definitely bad.
02 01
03 04
02 01
03 04
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
