hit the gas, Than it starts
Old 03-12-2006, 10:38 PM
  #41
I tend to get a bit irritable
Pearl96Max's Avatar
Originally Posted by umair01
remote starter can cause that...
That is quite incorrect.
Pearl96Max is offline
Old 03-12-2006, 11:50 PM
  #42
smaye's Avatar
Originally Posted by smaye
Me too. I can't see why a new grounding cable for your starter has anything to do with a car that is turning over like crazy, yet not starting.
I stand corrected. I was reading on troubleshooting the crankshaft positioning sensor and found that you are suppose to ensure the ground strap (to the engine block) is good, tight, and clean. The next step involved testing voltages at the POS sensor sub-harness.
I guess a poor ground would affect these voltages and therefore the POS count which could affect starting.
smaye is offline
Old 03-13-2006, 05:59 AM
  #43
This ORG has saved me $$$$$$$$
Juicey's Avatar
I have a similar issue, but my 1999 Max (113,000 mi) at times will just spin away with no hint of starting.
If I am lucky I can pump the gas pedal or hold to floor and it will start. Any relation to this issue?
I'd say I'm 70% sure your starter is going bad.
Juicey is offline
Old 03-13-2006, 11:25 AM
  #44
SoLid97SE's Avatar
well i just fixed my car this weekend. changed the plugs and it didn't help. ill99max helped me out and suggested i change the fuel filter, and for 16.95, the car starts instantly. if its been a while since you changed this i recommend you try that before the starter.
SoLid97SE is offline
Old 03-13-2006, 03:45 PM
  #45
tranz's Avatar
where is the Engine Coolant Temperature Sensor (ECTS) located?
tranz is offline
Old 03-13-2006, 06:40 PM
  #46
1996blackmax's Avatar
If you follow the upper radiator hose, the one on the driver's side you will get to it. It is the bigger sensor right after the connection of the hose to the engine. Can't remember if it's the first one or not, just the bigger one. The smaller one is for the temp gauge in the dash.
1996blackmax is offline
Old 03-13-2006, 06:52 PM
  #47
aspsmax's Avatar
just as a quick reference... if its a slow cranking then it could be electrical...(starter, ground wires, or even an incorrectly installed remote starter).. if it cranks at anormal speed, kinda starts, but dies.. then it could be the following: plugs, fuel filter, tb, ects, cold start injector(maybe but prolly not) (did i miss any?) maybe egr... try running fuel system cleaner thru to it might help...
aspsmax is offline
Old 03-14-2006, 07:03 AM
  #48
NAPhi_Shift's Avatar
hey to the guys that have cleaned out your throttle bodies, i have done the same thing... does your engine still idle higher? i cleaned my tb and the car idles at 1000... i think im gon have to end up playing with the TPS and lower the idle revs
NAPhi_Shift is offline
Old 03-14-2006, 01:58 PM
  #49
Mr Willis's Avatar
WOW, thank all of you for your responses. Unfortunately i have recently been in the E.R. because i have kidney stones and now i'm pretty much stuck at home trying to pass them. So i can't get out to do anything u guys have suggested but when i'm better i will try them.
Thanks again
Mr Willis is offline
Old 03-15-2006, 06:06 AM
  #50
North's Avatar
it hasnt been mentioned yet but possibly injector o rings. It was an issue on my 240, and from what i understand, its fairly common with 240s. So if everything else doesnt work, its a fairly inexpensive try. good luck with those stones man.
North is offline
captchaos
03-15-2016 12:18 PM
dcam0326
09-07-2015 07:26 AM
trungg86
09-04-2015 04:58 AM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: hit the gas, Than it starts
