hit the gas, Than it starts
Old Mar 5, 2006 | 01:48 PM
Mr Willis's Avatar
Anyone know why my car will not start until i turn the key and give it gas. If i just turn the key it wil not start, just rev up and die. For this reason i cant use my remote start. But if i give it gas just 1 time it will stay on. All help is appreciated.
WOOT WOOT i can finally post new thread's.
Old Mar 5, 2006 | 02:03 PM
Trajiksmax's Avatar
Proud Maxima Owner
Maybe the remote starter could be the cause of the start problem.
Old Mar 5, 2006 | 02:12 PM
Mr Willis's Avatar
i doubt it because it cranks and everything.It just seem like the engine doesn't get enough gas to start until i press the gas peddle. Thanks for the response though.
Old Mar 5, 2006 | 02:20 PM
1996blackmax's Avatar
Try cleaning out your idle air control valve (IACV). Might be a good idea to clean out the throttle body while your at it too.
Old Mar 5, 2006 | 02:58 PM
96customax's Avatar
i have this same problem but more so when it is colder ouside...any body?
i have cleaned my throttle body and iacv...
Old Mar 5, 2006 | 03:08 PM
Check your Engine Coolant Temperature Sensor (ECTS) to make sure it is within spec.
Old Mar 5, 2006 | 06:32 PM
Mr Willis's Avatar
Yeah it only happens when it's cold. You're right!
EDIT: actually no it happens regardless of weather now.
Old Mar 5, 2006 | 06:44 PM
bl929rr's Avatar
I just picked up a 98 GLE that is doing the same thing. It only does it in the mornings after the car has been sitting all night long.
Old Mar 5, 2006 | 06:51 PM
darklegend06's Avatar
Check your spark plugs. I had the issue until I changed my spark plugs. They were just old. Now it's a perfect start.
Old Mar 5, 2006 | 08:52 PM
97green's Avatar
clean your throtle body.... it should fix it.
Old Mar 5, 2006 | 08:53 PM
steve95gle's Avatar
same problem
hey guys, im in the same boat exactly. i have done mostly all the things people have suggested, plugs, throttle body, iacv, fuel filter.....i just read in a different post that new grounds to the starter and transmission have solved this problem....i hope so...because what is the point of having remote start if you cant use it. maybe someone else can help?
Old Mar 5, 2006 | 08:56 PM
umair01's Avatar
remote starter can cause that...
Old Mar 5, 2006 | 09:28 PM
Mr Willis's Avatar
I'm pretty sure it isn't the remote start because it does it even when i start it manually in the morning.
Old Mar 6, 2006 | 05:09 AM
njmaxseltd's Avatar
Buy a Haynes shop manual and do some trouble shooting. There is a cold fast idle plunger and linkage that opens the throttle plate when the engine is cold. If thats not adjusted correctly or the plunger isn't working your going to have cold start problems as you described.
Old Mar 6, 2006 | 05:15 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
I had the same problem. Check your battery first. Make sure you have enough CCA (cold cranking amps) to start. Clean your TB. I didn't touch the IACV because it involved replacing a gasket and messing with a screw that for most people on this forum screws up their car.
I replaced my battery, cleaned my TB and bought a new starter and the car works fine now.
Old Mar 6, 2006 | 06:09 AM
96mAx2fast's Avatar
Sup guys, I'm having the same problem. Well, first of all, the starter was bad. I replaced it and now the car starts fine. Now, when I remote start it, sometimes it does the same thing. This morning it turned off about 3 times. I finally went outside and manually had to start it. I also noticed that there was antifreeze all over the floor but that is a seperate issue.. lol.. I have a new battery, new starter, new air filter, 1 yr old spark plugs and this still happens to me!! How do you clean your IACV and the throttle body?
Old Mar 6, 2006 | 06:13 AM
ziya20's Avatar
like "njmaxsaid", check and adjust Fast Cam Idle. That is what my problem was.
Old Mar 6, 2006 | 07:25 AM
SoLid97SE's Avatar
i have the same damn problem. the car runs perfectly when it does start, but if i don't gas it while turning the key it won't start. could be the plugs, but wouldn't that affect performance when the car is on also? and where is a cheap place to get a starter?
Old Mar 6, 2006 | 07:54 AM
Biggs_02's Avatar
i don't think it's remote start....most remote start has got a starter cutoff...where if you don't turn the alarm off it'll not allow someone with a key to crank...but this is different...the car is able to crank.
Old Mar 6, 2006 | 11:16 AM
Tim96I30t's Avatar
I had that problem right before my starter was replaced, only when it was really cold out. Since I have had the new starter even on the coldest days after sitting it cranks right over and runs fine. Before I had to give it a little gas on very cold days.
Old Mar 6, 2006 | 12:15 PM
SoLid97SE's Avatar
where's the cheapest place to purchase a starter?
Old Mar 6, 2006 | 12:28 PM
SoLid97SE's Avatar
and if anyone has a link for instructions on how to change it, that would be great. thanks
Old Mar 6, 2006 | 03:08 PM
JwaxMax99's Avatar
http://www.worldpartsexpress.com
Old Mar 6, 2006 | 03:28 PM
I bought mine at Autozone for about $150 bucks. I think it has a lifetime warranty. Pretty easy to change out. Get a Haynes manual if you do not already have one, very helpful tool.
Old Mar 6, 2006 | 06:22 PM
the_3d_man's Avatar
If it only happens when it's cold then 1996blackmax was prolly correct... try replacing the ECTS...
Old Mar 9, 2006 | 12:06 PM
Killiandw's Avatar
OMG I thought I was the only one with this problem...My 95 Max won't start in the morning when its cold and its been doing that way before I got a remote start. I have replaced starter with a nissan one didn't help...done tune up no help...my machince says it could be my knock sensor also still waiting to get some money to fix that but in the mean time i will try the other things u guys suggested.
Old Mar 9, 2006 | 12:12 PM
Mr Willis's Avatar
exactly. Me too
Old Mar 9, 2006 | 01:32 PM
eckounltd287's Avatar
Likes them corn fed
same problem here.. i just cleaned my throttle body today. and it idles higher now... one mechanic told me that it can be my " cold fuel injector" supposedly its a seperate injector that gives it a little more gas when its cold to prevent it from shutting down.
Old Mar 9, 2006 | 08:36 PM
maximaxgtr's Avatar
I had the same issues where my car would just stall after starting it on a cold morning (below 40 degree F). I cleaned out all the gunk out of my throttle body (with a toothbrush, some throttle body spray cleaner, and towel). Now, the car starts fine, and yes, it will idle at 1k and slowly drop down when warming up, which is fine! Hopefully that will fix your issues of starting it cold.
Old Mar 9, 2006 | 09:03 PM
TLMNICK's Avatar
I sometimes have that problem. The thing is it went through most of the winter without that issue...even on the coldest days we had. Recently when the morning was a bit warmer...it gave me that problem...so confusing.
Old Mar 10, 2006 | 03:11 AM
smaye's Avatar
I have a similar issue, but my 1999 Max (113,000 mi) at times will just spin away with no hint of starting.
If I am lucky I can pump the gas pedal or hold to floor and it will start. Any relation to this issue?
Old Mar 10, 2006 | 06:17 AM
SoLid97SE's Avatar
mine has progressed on to doing this. before it would start then die (it started doing it 2 winters ago on the coldest days) and now i have to give it gas or it keeps cranking. i'm changing out my plugs tomorrow to see if thats the issue, if not then the starter next. if that doesn't fix it then i guess i gotta go to a mechanic.
Old Mar 10, 2006 | 06:25 AM
Juicey's Avatar
Check your grounding as well. A new starter fixed my problem, as well as a new battery. I would check the battery. If OK, check grounding, finally I'd look for a starter. Go from cheapest to most expensive.
See this thread for grounding:
http://forums.maxima.org/showthread.php?t=452286
Old Mar 10, 2006 | 07:07 AM
SoLid97SE's Avatar
that actually sounds like the issue i have, where it cranks, stop for a split sec and then keeps cranking. where else can i purchase 14 gauge wire with connectors?
Old Mar 10, 2006 | 07:48 AM
Dodd's Avatar
I had the same problem this winter when it got really cold, apparently the starter solinod fluid frooze or something. Im not a mechanic so i just took what he said to be the truth.
Old Mar 10, 2006 | 10:13 AM
SoLid97SE's Avatar
can someone explain to me why grounding cables could be a possible solution to the problem? i don't quite understand. if the car started fine before without the grounding cables then why the sudden need, especially with lower temperatures?
Old Mar 10, 2006 | 10:37 AM
Likes them corn fed
cleaned out my throttle body.. works well... it starts now, with out me pressing the gas.. although it was a bit warmer today..
somehow my car seems slower.. not as torquey as when it was dirty,
Old Mar 10, 2006 | 02:52 PM
smaye's Avatar
Me too. I can't see why a new grounding cable for your starter has anything to do with a car that is turning over like crazy, yet not starting.
Old Mar 11, 2006 | 03:08 PM
SoLid97SE's Avatar
i changed my plugs which didn't help with the starting, but changed the fuel filter and now the car starts well. no grounding necessary here...
Old Mar 12, 2006 | 11:07 AM
pilotmaxima's Avatar
I had the same problem. I had to pump the throttle to start it, and a few other idle issues. I cleaned the IACV and throttle body and it works great. Thanks for the advice.
