replacing tps what position to screw it on at?
Old Mar 10, 2006 | 11:59 AM
chillin014's Avatar
the 2 screws on the tps go through those thin long holes which allow movement of the TPS. should i make it to where the screws are in the middle, cause this makes the butterfly valve open a bit.
i dont know what position to put it in ! i need help kind of quickl ycause i want to put the car back together.
Old Mar 10, 2006 | 02:22 PM
chillin014's Avatar
found a website through the stickies nvm
Old Mar 10, 2006 | 03:35 PM
chillin014's Avatar
unfortunately even with the "how to" i cant do it. i have a voltage meter and its just not giving me any reading on the TPS. i dont know what to do, i cleaned the IACV as well so i know this could be playing another variable so really all i can do is go by the voltage meter for whether the TPS is positioned correctly.
i've never really used a voltage meter before...but i need help...
Old Mar 10, 2006 | 07:34 PM
BigLou93SE's Avatar
You're going to have to "back probe" the sensor - putting pins into the "gummy" area of the sensor, where the wiring goes into the sensor. From there, you can use alligator clamps to connect the voltmeter to the pins, and get a reading. Let me know if you need a better explaination, it's been a long time since I did this.
Old Mar 10, 2006 | 07:38 PM
chillin014's Avatar
im gonna check it out tomorrow.
turns out i instaleld it where the little piece was catching BEFORE the "t" and not after. i created a thread in the all motor sectio nwith better details cause i wasnt getting any response here, but im not there either.
it runs okay now, but needs to be adjusted.
thanks for the help, im gonna try to see what your talking about tomorrow after work
Roymg
Sep 3, 2018 05:10 AM
schmellyfart
Sep 25, 2015 04:47 PM
Stelianos
Aug 19, 2015 02:07 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
