Air Bag Light
Air Bag Light
My air bag light has been flashing for a couple weeks now. I'm guessing it's just a bad sensor or something. Hopefully it doesnt explode in my face.
What should I do and where should I take it? Is this a dealership issue? Can I diagnose the problem without taking it somewhere? Note: I have a 99 and you can't pull the codes like you can on other 4th gens, plus the CEL light is Not on.
Can anyone help me out or point me to a Sticky that deals with this problem. Thanks!
my air bag used to blink. there is a sequence to turn it off. i forgot though. heres a rough idea though. turn key on and off without starting car. then with key in off, push the driver door jamb button by the b pillar. the thing that turns the dome light off. 5 or 6 times in 7second. if done right the light won't come on. i have been driving like an azz for a month and still no light. also i got the squence off my snap on scanner, the graphic one, it knows it all. i love that thing. jsut a thought. if i remember, i will check on it or do a search on here.
Dstyle, it could possibly be a air bag control module. Mine went on the side air bags of my 98 SE, which was the first year of their availability. Have it diagnosed and check the code. I don't see the sense of just "resetting" the light, obviously there is a problem and your air bags will not deploy in an accident... its your choice.
How old is your battery? Mine was on and someone told me to check the battery. If the battery drops below 9 volts it will trigger the air bag light. Have it tested. Mine failed and I replaced it. The light stayed out after resetting it a couple of times.
First check the stickies... and reset the light.. you may need to try a few times... but if it does not work you have a bigger problem
there is a TSB on it, the module has a problem with the Module having too short of a harness and it gets pinched and causes the Pass side air bag in the seat to not work triggering the Airbag light.. causing the system to go in safe mode... the module is around $300 alot better than buying a new airbag for $600 to $1k
TSB# ntb000043
NTB00043
If a 1998 or 1999 Maxima has the SRS light flashing, and self-diagnosis indicates either Side Module LH [OPEN] (code DA) or Side Module RH [OPEN] (code 7A), install a SRS side air bag module of the type indicated in the Parts Information section of thisbulletin to resolve this incident. This new side air bag module (with long harness) replaces both the air bag module and the seat sub-harness. See this bulletin for further details.
Part number K8EHM-7L002 Module A
Local dealer qouted me here $395
hope this helps
TSB# ntb000043
NTB00043
hope this helps
sdotcarter
09-02-2015 09:53 PM
