Anyone running with Intrax springs?
What kind of struts you have? Stock or otherwise? I have Intrax springs on mine, but running on stock struts. I think it's almost time for me to replace them. What kind of do you guys have? And how are they, do you like them? I think I'll go with Koni struts. Or should I just replace the springs as well? Any suggestions would help. Thanks.
http://forums.maxima.org/search.php?...der=descending
Looks like a few are/have done what you're doing.
I think Konis would serve you well with the "more severe" drop of Intrax springs....
I'm in the same boat!
I too have Intrax on stock. I wouldn't say I 'have' to get new shocks like you are saying (I was told over 50,000 miles ago that my stock shocks wouldn't last more than 10,000 miles with the Intrax!!), I just can't take the ride anymore. I have been doing my homework and I found (please anyone feel free to add to this) that the best ride with lowering and handling is the H&R/Tokico combo. So that's what I'm going with (probably some time this summer). I will really miss the low look of the Intrax (although I have to admit it will be nice to not scrape my nose as much). So did I answer your question? Probably not. If you want a nicer ride, dich the Intrax and get shocks and springs together (H&R/Tokicas, H&R/Konis), or if you are simply getting new shocks/struts, get Tokicas or Konis. Just my opinion - do your homework first - but I am sharring what I got from my homework. Good luck and let me know what you decide!
ptatohed@netzero.net
(contact me if you want to buy my Intrax)
Re: I'm in the same boat!
Thanks. Yes, your info did help a bit. I too thought about going with the H&R with Konis. The ride is just too much for me too. And if you want that even lower look, you can always get a whole Stillen aerokit. It would make your car look lower than it is. Currently with my Intrax and Stillen front lip spoiler, I scrap quite often. Especially, with the horrible roads here in New Orleans. Low looks good, but down here, we got to watch out for the floods!
Originally posted by bill99gxe
Search results for "Intrax opinion" on 4th gen forum:
I know Bill, but the search option has been acting up lately. Last few times I tried, it came up with nothing. Maybe it works now, who knows. I remembered searching for my own username, for example, and it came up with "no match". Ok...thanks anyway though. Btw, I always do search first, unless the search function is acting up. I didn't this time though because I never had good result with the search thingamagig.
I think the INTRAX with KONIs are fine...
I just (re)set my rears to near full stiff(about 100 degree turn away from full stiff) and I think it's too much stiffer and little in terms of payoff in handling compared with full soft which I had earlier... I'm probably gonna take the backs out again and have them reset to 50%...
BTW, the Fronts DO make a HUGE difference in handling when you adjust them up from full soft... I have mine set to about 180 degrees from full stiff... they're easy to adjust anyways...
ballerchris510
Sep 10, 2015 09:35 PM
