need feedback form bosch platinum users
Old Mar 16, 2006 | 12:19 AM
zarek66's Avatar
just wanted some feedback from people who use bosch platinum on their max. I know most of you will say stick with ngk. but at .99 cents a piece for platinums it sure is tempting. so let's hear about your experience with bosch platinums. oh by the way do the bosch come pre-gapped?
Old Mar 16, 2006 | 04:16 AM
Maxima880's Avatar
I've used them for a number of years. When they come out at about 40,000 miles they always look good - Like they could have lasted twice as long. They seem to run fine in the car - But then again either a spark plug works or it dosen't. There's not much in between.
Old Mar 16, 2006 | 04:42 AM
cleanmax's Avatar
i never use them because everyone i know always wants to throw them away because they suck. stick with ngk, denso, or slitfires. (the v plugs)
Old Mar 16, 2006 | 04:56 AM
MaximaSE96's Avatar
Maxima Owner
last time i used bosch platinums the elctrode broke off and shot into one of my injectors....i am sure it was isolated incident but that ruined my image of them forever
Old Mar 16, 2006 | 05:08 AM
s0ber's Avatar
eh... bosch = crap...
/thread
Old Mar 16, 2006 | 05:11 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
The Bosch platinum four prong I bought came pre-gaped. I've had them in so long I can't really remember what a "regular" spark plug is like. So far I've had great gas milage and no problem starting (that is any starting issues caused by the plugs). I hadn't even heard of NKG until I joined this forum months ago.
Personally I think they are fine for me. If I was out to run races I wouldn't attempt to do it in a four door sedan. Know what I'm saying?!
Old Mar 16, 2006 | 06:01 AM
clive's Avatar
100% chingon
I replaced the original NGK platinums about 3 months ago with Bosch. The car has run really well since then. No problems with performance or mileage.
Old Mar 16, 2006 | 06:53 AM
Flava_24/7's Avatar
Boosted Panda
When I fist got my max, I put some in not knowing better. It ran fine for a while. But after i started getting on the car they began to crap out. The car would idle real rough and bog out. Kind of like if I had a bad coil.
Put in the NGK platinums and have done so ever since and the car has runs fine ever since.
Old Mar 16, 2006 | 07:12 AM
ronin22357's Avatar
I did the same thing as flava, same thing happened me too! Learned my lesson , go with NGK's
Old Mar 16, 2006 | 10:01 AM
Tarzan26's Avatar
plugs
I had a bosch plug not only detonate but fall apart... it lost the whole end of the plug when i took it out it lot the arm the electrode and the ceramic... all that was left was the metal piece that goes from the top to where it gives spark..
that was two weeks ago i had to buy a new engine because the metal parts cause one cylinder to have zero commpression!
so ya i did use them for two changes before but i had one bad one and it costed me an engine swap!
my feeling is they all work the same but quality control is what your paying for!
buyer be where!
Corey
Old Mar 16, 2006 | 10:21 AM
95bluse's Avatar
You have a high performance engine with a high performance ignition system. Do not put cheap, crappy .99cent Bosch in there, you'd probably suffer higher fuel consumption + your car will hate you and run horribly just to p!ss you off .
Joking about the last part, but seriuosly...don't do it. If you don't have the money right now, just buy some NGK BK5RE-11. They are just as good as platinum, just not as long-lasting.
My .02cents
Old Mar 16, 2006 | 10:38 AM
SDot82's Avatar
My friends 96 maxima would not even start when we put Bosch platinum plugs in. Went back and got some denso's started right up.
Old Mar 17, 2006 | 09:05 PM
maximafrenzy's Avatar
Fuhget About It.....
I put the Bosch in my car not too long ago, now you guys are freaking me out, Im changing them as soon as I get some NGK's. On the plus side I have no problems for now.
Old Apr 10, 2006 | 08:32 AM
KiNgJaMEs's Avatar
bosch is crap i used NGK for now on out they had my car skipping like the tranny was going out. thanks to the tranny guy at Nissan he told me to change to NGK and it fixed my prob
final answer dont use Bosch
Old Apr 10, 2006 | 10:49 AM
BSwithTF's Avatar
I had an unmodded '96 SE walk away from my '96 GXE (I/Y/E) a couple days after I put +4's in. Next day, changed to NGK Plat's and we raced again and my GXE beat the SE easily. That was proof enough for me.
Old Apr 10, 2006 | 11:17 AM
zander's Avatar
weird, that may have been my problem. The car would pull hard sometimes, and not so hard other times. I'll switch to the NGKs and see if it actually makes a difference. I was still getting 23mpg mixed.
Old Apr 10, 2006 | 01:20 PM
motocross416's Avatar
I have bosch platinums in my car, about 10k miles on them and still running perfect. I put them in my brother's 97 max and it fouled them out after 6k miles. no idea how it happened
Old Apr 10, 2006 | 01:42 PM
Bobo's Avatar
I still have the original NGK platinum plugs in place that came with the car when I took delivery on October 1, 1994. The car has 63K, mostly highway miles on it, and runs like a champ.
I had no problem with emissions testing last September and I have a Budget y-pipe.
I will replace the original plugs with NGK platinum plugs when the time comes.
My car has mostly highway miles on it, the fuel economy is as good as day 1 and I see no need to replace the plugs until I have to go through emissions testing again in the fall of 2007, at which time the plugs will have less than 75K on them.
I wonder how many sets of NGK copper plugs I would have gone through in 13years, certainly more than 2.
Old Apr 10, 2006 | 04:18 PM
kcryan's Avatar
No no to bosch, NGK is the way to go, esspescially boschs +4's are ****, they sheild the spark among other things
Old Apr 10, 2006 | 05:29 PM
Buck96's Avatar
I use bosh Platinum 2's.
It's a personal preference. Its depends on your driving style wither you'll like traditional gapped plugs or plugs like these with a free Open electrode on the end. If your going to use bosh plat's at least use 2's or better.
If your unsure stick with the NGK Plats.
James92SE
142
Jan 2, 2024 09:23 AM
Maximan190
Dec 16, 2015 06:01 AM
MannyMonroe
Sep 25, 2015 12:38 PM
