Few ECU codes
Old Mar 16, 2006 | 06:01 PM
WielkiWaac's Avatar
MaximaDriver
Few ECU codes
ok guys. today i pulled put couple codes from my ECU.
So i have
- P0325,
- P0141,
- P0600,
- P1605,
I hnow how to hadle 1st two of them, but the last two I dont.
And here is story. My max was automatic, now is manual.
Is there any way to clear that codes?? or just repalce ecu from manual.
thanks
Old Mar 16, 2006 | 07:29 PM
pmohr's Avatar
No more Maximas...
Did you unplug the TCM when you did the tranny swap?
It's best to have a ECU that matches the year/transmission you have, as far as codes go.
Old Mar 16, 2006 | 09:52 PM
maximaman10's Avatar
PO325 is your Knock Sensor
PO141 is your rear oxygen sensor
PO600 is your auto trans.commuincation line
PO1605 A/T Diagnosis Communication Line
Old Mar 17, 2006 | 03:03 AM
WielkiWaac's Avatar
MaximaDriver
i removed TCM from my car
Old Mar 17, 2006 | 06:37 AM
I30tMikeD's Avatar
Putting in a manual ECU will probably cause more bogus CEL's.
Old Mar 17, 2006 | 06:40 AM
Kevlo911's Avatar
Kevlo for President
Why would it cause more codes? He is no longer auto so it would get rid of the auto CELs.
And there is a good chance his KS and Rear o2 are dead.
Old Mar 17, 2006 | 06:49 AM
I30tMikeD's Avatar
the only way to avoid CEL's when using another ECU is to use one with the exact same PN. The # listed on the large sicker on the face of the ECU.
Your not gonna be able to match that up using a different tranny type ECU, even everything else being the same.
Old Mar 17, 2006 | 06:51 AM
Kevlo911's Avatar
Kevlo for President
Yeah I got ya. He has a 99 so I doubt he has many options for other 99 ECU's anyways. Unlike the 95-96 which have TONS of different kinds.
Old Mar 17, 2006 | 07:31 AM
WielkiWaac's Avatar
MaximaDriver
so what should i do with it??
will i pass emision test if codes are showing tranny problem not the engine??
Old Mar 17, 2006 | 07:59 AM
Kevlo911's Avatar
Kevlo for President
Find an ECU with the same build dates and things like that on car-part.com for a 99 manual.
Old Mar 17, 2006 | 08:12 AM
I30tMikeD's Avatar
Really, they shouldn't care if it's not emissions related. But I would bet any CEL will cause you problems getting passed. IL is **** about that. That is why with all my modifications I have had to plan to be able to get my car CEL free at least a few days for emissions testing. Thank God I am moving to a state where there is no emissions testing at all.
Old Mar 17, 2006 | 08:14 AM
Kevlo911's Avatar
Kevlo for President
FL
Old Mar 17, 2006 | 08:16 AM
I30tMikeD's Avatar
FL
OK
Old Mar 18, 2006 | 02:45 AM
WielkiWaac's Avatar
MaximaDriver
ok. ijust did some research on car-parts.com and it showed me a lot of options.
My max is was made in 10/98, so for sure i have to find ecu from that month. But i saw there ECU's from SE, GXE, GLE - auto which i dont need,
May i just get any ecu from 10/98 with manual tranny??
Old Mar 18, 2006 | 06:16 AM
Kevlo911's Avatar
Kevlo for President
Get one from a SE.
Also you might have to get your key reprogrammed because of the chipped key.
Old Mar 18, 2006 | 06:57 AM
WielkiWaac's Avatar
MaximaDriver
Get one from a SE.
thanks.
now i know what should i look for
Old Mar 18, 2006 | 08:15 AM
RA030726's Avatar
I'm nutty for Nissans
as far as the KS and O2 code, replace the O2 sensor first then reset the ecu and drive for a while. this is because sometimes the KS code shows up with other emissions codes when it has not failed. its a false reading. but if the code reappears by itself, then go ahead and replace it.
Old Mar 18, 2006 | 11:14 AM
ProjectMax96's Avatar
I had a code also.
P 0174...any idea what that one is?
Old Mar 18, 2006 | 11:58 AM
RA030726's Avatar
p0174 is fuel injection system lean (left bank)
Old May 6, 2006 | 06:48 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
I have the same issue.
Today I replaced my ECM to manual tranny, The codes i am getting are p0600, p1605. Can someone tell me where is the automatic Trannny TCM located?
My car is a 99 GLe.
Old May 7, 2006 | 07:52 PM
CystumMax's Avatar
can someone response?
Old May 8, 2006 | 11:25 AM
pmohr's Avatar
No more Maximas...
My car is a 99 GLe.
The TCM is directly below the BCM. Remove the radio and other center console accessories and it has the large blue connector(s) underneath the black box which is the BCM. You also may be able to just remove the shifter trim and unplug the TCM, but I doubt if you could reach it through there.
Old May 8, 2006 | 12:19 PM
WielkiWaac's Avatar
MaximaDriver
My car is a 99 GLe.
are you converted to 5 spd??
let me know which ecu dod you get. i need it to pass emission test next year
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
