Failing Ignition???
Old Mar 17, 2006 | 11:42 AM
Sarah99GXE's Avatar
Maxima Princess
Failing Ignition???
A couple months ago we had to replace the starter because I was having slow starts and then the car finally died.
Everything has been fine.
Over the last couple of days, (and this has happened to me 2 times now) I go to start my car and nothing happens. Not a click, or noise, nada. My battery is good (because my wipers came on accidentally and my lights work). When I go to turn the key a second time it will start right up.
Is this a sign that maybe now my ignition is wearing out?
Thanks,
Sarah
Old Mar 17, 2006 | 11:53 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
The electrical portion of your ignition switch is wearing out. It happened to me about a year ago. Cost about $200 to replace, maybe a little less, I dont remember.
Old Mar 17, 2006 | 01:20 PM
clive's Avatar
100% chingon
Yep. That's it. Mine too. It's a frequent problem on Nissans. I had to have my Sentra ignition parts replaced. You can keep the same key, it is the part inside the column assembly that goes bad.
Old Mar 17, 2006 | 01:22 PM
Sarah99GXE's Avatar
Maxima Princess
any ideas on how to replace this? Is it easy??
Old Mar 17, 2006 | 02:36 PM
JwaxMax99's Avatar
Sounds more like a bad ignition switch, under the steering wheel, $30 part or so, and easy to replace.
Old Mar 17, 2006 | 03:36 PM
Sarah99GXE's Avatar
Maxima Princess
Now that sounds like an easy cheap thing to start with....if and when it starts happening more. Anything I need to know when getting the part? Any write up on exactly where this is located (picture of it??)
Old Mar 17, 2006 | 03:38 PM
Kevlo911's Avatar
Kevlo for President
Check the 4th gen How To's for the write up.
Old Mar 17, 2006 | 07:39 PM
Sarah99GXE's Avatar
Maxima Princess
Thank you.
Old Mar 18, 2006 | 12:43 PM
tfult1's Avatar
30 min fix
My 97 did the same thing 3 mos. ago. $30 part online and takes about 30 minutes to replace. Just remember to disable air bag when working on the steering column. good luck
Old Mar 19, 2006 | 01:12 PM
Sarah99GXE's Avatar
Maxima Princess
Good Point! How do I do that?
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
msellas
Sep 23, 2015 09:16 PM
JoshG
51
Sep 21, 2015 10:41 PM
rnb754
Sep 14, 2015 11:39 PM
