just got a 5spd swap and have some questions/concerns
Old Mar 17, 2006 | 08:36 PM
ukraini9mofo's Avatar
well I have a 99 and my CEL light is on , so I guess to make it go away i need a new ECU, I was wondering will any manual ECU 95-99 work and also what if i get a 99 is the chip in the key stored in the ECU?
also often when the car idles in neutral, the rpms stay at 1.5 then after 5 secs or so they will drop
Thanks for any suggestions
Old Mar 17, 2006 | 08:53 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
You have a CEL because you are still using your auto ECU, you need a manual ECU and I think, (not 100% sure) you need a 99, I believe the previous years are different.
The idle problem might be a problem with your IAC or PCV, try cleaning the IAC and or replacing the PCV.
Old Mar 18, 2006 | 06:13 AM
abci30's Avatar
oh noes!!!!1111
you need a 99 5 speed ecu i don't know about the security key thing. The reason why your idle is high is because you are still using an auto ecu. Once you get the 5 speed on it will not continue to do this.
Old Mar 18, 2006 | 07:53 AM
thanks alot guys but now does anybody know will my keys not work with the new ECU?
Old Mar 18, 2006 | 10:50 AM
Vlasic's Avatar
I think your keys should be fine. The code for that chip is stored in the ignition housing I think.
abci30: are you sure about the idle problem being because he still has an auto ecu? I have two friends who did 5 speed swaps, one on a 2k1 and one on a 95 and they both still have the auto ecu with no idle problems.
Old Mar 18, 2006 | 11:16 AM
99 SE-L
Imo This is the ECU, becuase his Ecu still thinks there is an Automatic transmission and letting the Rpm's stay high, While in neutral then they begin to fall.
Old Mar 18, 2006 | 08:24 PM
davey6693's Avatar
shiet....I'm doing a 5 speed swap soon and don't want to see the CEL on. Has anyone done the swap and not got a CEL without changing the ECU?
Old Mar 18, 2006 | 09:34 PM
abci30's Avatar
oh noes!!!!1111
i'm 100% sure its the auto ecu messing with the idle because of what was mentioned above
Old Mar 19, 2006 | 01:01 AM
Vlasic's Avatar
You WILL get a CEL no matter what if you do a 5speed swap and dont change the ECU. The auto tranny has a bunch of sensors and harnesses on it and when you convert to 5speed, those connectors are just left un plugged, so the auto ECU thinks something is wrong. I dont see what the big deal is tho. Ive been driving with a CEL for months now, I could care less.
Old Mar 19, 2006 | 03:46 PM
alright so you thin i will be able to use any ecu 95-99? And also is anybody 100% sure that the chip codes are in the ignition?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
