what muffler? welding? advice plz
Old Mar 18, 2006 | 04:24 AM
kkw1004's Avatar
hi
I put a new y-pipe on my Maxi and when they lifted up my car, I found that muffler need to be changed in near future.
I have researched couple days for mufflers and I am not still sure about what is good muffler to my Maxi.
I want a quiet one in idle and I want a loud when rpm goes over 2500 rpm while I am accelaration. any recommendation?
also If I pick universal muffler, does it have to be welded?
Is there any muffler that I can do it myself?
when I checked my muffler, It was connected b-pipe with bolt and nuts.
any idea, appreciat it
thanks
Old Mar 18, 2006 | 07:17 AM
9maxima5's Avatar
A universal muffler will need to be welded. Yes there are cat-back kits and just rear section mufflers for our cars and u can do it urself. There is a thread on the top of the 4th gen page dedicated to exahusts I would listen to the clips to see wich you prefer.. Good luck.
Old Mar 18, 2006 | 08:26 AM
kkw1004's Avatar
THANKS FOR YOUR ADVICE.
I HEARD THOSE SOUND CLIPS AND I WASN'T SURE WHICH ONE I REALLY LIKE B/C EVERYONE HAS DIFFERENT Y-PIPES AND B-PIPES, ALSO SOMEONE HAS A RESONATOR.
IT WAS KINDA HARD TO TELL FOR ACTUAL MUFFLER SOUND ITSELF.
RIGHT NOW I GOT BUDGET Y-PIPE AND REST OF MY EXHAUST SYSTEM IS STOCK ONE.
THANKS ANYWAY, I WILL SEARCH IT LITTLE MORE
ANY GOOD MUFFLER BRAND?
REASONABLE PRICE?
IF I NEED RESONATOR, WHERE IN EXHAUST SYSTEM I PUT IT?
THANKS
Old Mar 18, 2006 | 09:10 AM
99grnmaxgxe's Avatar
You can put the Stillen muffler on by yourself, direct bolt-on. Kind of expensive though.
Old Mar 18, 2006 | 11:17 AM
kkw1004's Avatar
I HAVE KINDA TIGHT BUDGET ($125-$150 MAX <INSTALLATION INCLUDED>)NOW.
SO I HAVE TO FIND SOMETHING GOOD AND REASONABLE PRICE.
I DON'T NEED FANCY ONE LIKE OVER $250. I JUST NEED SOMETHING HAS BETTER SOUND THAN STOCK AND SOMETHING THAT I CAN DO IT MYSEFT WILL BE PERFECT.
WHICH WAY IS BETTER TO PUT IT ON ? (1. DIY, 2. WELDING FROM SHOP) I THINK WELDING IS EASIER AND CHEAPER, RIGHT? BECAUSE YOU NOT DOING IT AND YOU JUST PAY IT.
I NEED SOME ADVICE
THANKS
Old Mar 18, 2006 | 11:56 AM
Tatanko's Avatar
Bacon Lover
Grab yourself a 5th gen muffler, have it welded in, and call it a day. I don't know why you're talking about a resonator when all you're doing is replacing the muffler
Old Mar 18, 2006 | 12:57 PM
kkw1004's Avatar
THANKS FOR THE INPUT
THE REASON WHY I MENTIONED ABOUT THE RESONATOR IS SOMEONE SAID THE IF YOU HAVE A MAGNAFLOW MUFFLER, YOU SHOULD HAVE A RESONATOR FOR BETTER SOUND (NOT TOO LOUD)
WITH THE 5TH GENERATION MUFFLER, I STILL NEED TO WELD IT, DON'T I?
THANKS
Old Mar 18, 2006 | 01:01 PM
Nissan 6's Avatar
Typing in CAPS is the equivilent of shouting. Please do not shout at me. If you are getting a fairly loud muffler that may be too loud, a bigger resonator will quiet it down.
Old Mar 18, 2006 | 02:44 PM
Fr33way™'s Avatar
Wild for Width
It's so loud in here.
I think most people are referring to aftermarket b-pipes when they say to get a new resonator. The stock one should do just fine.
Old Mar 18, 2006 | 04:52 PM
kkw1004's Avatar
Sorry guys
I didn't know that Caps mean shouting.
I will remember that
Old Mar 18, 2006 | 04:54 PM
kkw1004's Avatar
so you are saying is that don't need to get resonator, right?
thanks again
Old Mar 18, 2006 | 05:27 PM
Northern Maxima's Avatar
I bought a stainless steel Borla muffler off Ebay for only $69...sounds great! My entire exhaust system is stock apart from this muffler. I find there is a drone from 2000-3000 rpms but otherwise its pretty quiet. It has a deeper grumble when its idling than the stock muffler and overall sounds pretty sport/aggressive. I'm very happy with it...always try to drive so I can hear it at its loudest! It has a 2.5" inlet/outlet so some welding had to be done to make it fit. Nothing major...I just had a local muffler shop do it for me.
I do have soundclips too...I can probably dig them up if you want to hear. Just PM me.
Old Mar 18, 2006 | 09:22 PM
kkw1004's Avatar
thanks for the info.
I guess I will buy the universal muffler and let muffler guy install for me.
does it has to be 2.5" inlet to be fitted?
let me know
thanks
Old Mar 18, 2006 | 09:30 PM
aih98max's Avatar
scoobystoned...
i bought a cheap straight through coffee can muffler off ebay and had a shop weld it on. it sounds sweet, but i cant stand the coffee can muffler look, so im gonna get a race series magnaflow oval muffler w/ 4 inch slant tip soon. the ebay muffler was like 25 bucks shipped.
Old Mar 18, 2006 | 09:35 PM
9maxima5's Avatar
I also had the ebay muffler on one of my maxima's, sound was good but the look was terrible. I next did flowmaster and then sold the car and now i just got the flowmaster muffler again. I love the sound. I would recomend a flowmaster 60 series. It's deep and not loud at all.
Old Mar 18, 2006 | 09:38 PM
86maxima96's Avatar
I Broke OT
i have heard good things about a Dynomax Super Turbo muffler. it would have to be welded on. you could go with a 2.5" or 2.25" inlet depending on future upgrade plans and whatnot. like you said, you're on a budget, and you shouldn't have any trouble buying a muffler and getting it installed for that price. good luck shopping!
Old Mar 18, 2006 | 09:39 PM
chillin014's Avatar
hahahahahahahahaha.
THANKS FOR HEARING THAT
THANKS FOR THE POST *****
Old Mar 18, 2006 | 09:45 PM
kkw1004's Avatar
thank for your advice.
I was thinking getting flowmaster.
ok is there anything I need other than flowmater muffler, when I go to muffler shop to install?
and what inlet size sould I get?
please help
thanks
Old Mar 18, 2006 | 10:04 PM
9maxima5's Avatar
I had bought the muffler at the shop. They had to run a little bit of pipe and the install and everything cost 130. I had a tip of my own so they also welded it on there. I dont have pics yet but i can get some later.
Old Mar 18, 2006 | 10:07 PM
9maxima5's Avatar
This is the tip I had on my old set up. The current one is a little bit bigger and I dont have duals anymore
Old Mar 18, 2006 | 10:37 PM
kkw1004's Avatar
I have a 1998 gxe maxima
what is the right inlet size for the muffler?
any input will be appreciated
thanks
Old Mar 19, 2006 | 08:45 AM
Stock size would be 2.25"
Old Mar 19, 2006 | 12:05 PM
aih98max's Avatar
scoobystoned...
id say go with the flowmaster or magnaflow. magnaflow universal mufflers already have nice looking tips, flowmasters you have to buy your own tip.
Old Mar 19, 2006 | 08:52 PM
kkw1004's Avatar
thanks for the tips.
the guy said stock inlet size is 2.25", then what inlet size universal muffler should I get? (2.25", 2.5" or what?)
plz give me some idea.
thanks
Old Mar 20, 2006 | 06:32 AM
kkw1004's Avatar
hi
please help me find right inlet size for 1998 gxe muffler and what inlet size of universal muffler should I get.
thanks for your time.
Old Mar 20, 2006 | 08:37 AM
Fr33way™'s Avatar
Wild for Width
Originally Posted by kkw1004
thanks again
That's what I'm saying. You don't need to.
Old Mar 20, 2006 | 08:38 AM
Fr33way™'s Avatar
Wild for Width
Originally Posted by chillin014
hahahahahahahahaha.
Stop shouting.
Old Mar 20, 2006 | 08:48 AM
MaximaSE96's Avatar
Maxima Owner
if ur staying with stcok piping sizes u need 2.25" inlet
Old Mar 20, 2006 | 09:31 AM
kkw1004's Avatar
thanks maximase96
I will go ahead and buy either magnaflow or flowmaster muffler.
thanks again
Old Mar 20, 2006 | 09:34 AM
chillin014's Avatar
I'm just teasing
Old Mar 20, 2006 | 12:40 PM
Keatz's Avatar
Guys i need help, i got a 98 max with a CE y pipe, CE high flow cat and a straight through cat back exhaust that has 2.5 inch piping along with huge no name coffee can muffler. Im tired of gettin tickets and headaches because of how loud it is.
Will the magnaflow or flowmaster decrease the sound level by a lot? if so which series or model should i go for????? Or if there is any other muffler out there than can get the job done while lookin good and sounding good?
Someone was also telling me that if i go with a different muffler, i may get problems related to pressure or something like that, any opinions on that????
Old Mar 20, 2006 | 02:38 PM
aih98max's Avatar
scoobystoned...
go magnaflow. thats what im doin this summer.
Old Mar 20, 2006 | 02:40 PM
aih98max's Avatar
scoobystoned...
i also have a no-name coffee can muffler (from ebay) but thats all i have on my exhaust, nothing else custom. im goin magnaflow because i like the look of them, and i think itd be quieter than my ebay pos.
Old Mar 20, 2006 | 06:59 PM
kkw1004's Avatar
check this website
http://maxmods.dyndns.org/index.php?MaximaMufflers
you will find some good info. and right muffler
good luck
Old Mar 21, 2006 | 07:12 AM
Keatz's Avatar
Thanks for the website, cleared up a lot of things. I almost went out and got a magnaflow but now that i know its too loud without a resonator, there is no way im getting that muffler.
I think im going to go with a flowmaster 60 series muffler and just buy a nice tip for it, but im still gonna wait before i do it, so more opinions are welcome
thanks guys
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
uttadms31
Sep 30, 2015 05:24 AM
