Cylinder 4 misfire
Cylinder 4 misfire
I have a 99 SE and am getting a code for a misfire in cylinder 4. From what I've read, it seems that this is a common problem caused by a bad ignition coil. My question is, which is cylinder 4? From what I can find, I believe it is the middle one of the firewall side, is that correct? Thanks
Easy fix
use above diagram... you can (if you shop around or go to autozone) get a cheap Ignition coil about $60 to $70... pay more & you're getting hosed. Simply unscrew two screws and disconnect pull out and do reverse. Don't even need a manual.
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
knight_yyz
11-01-2015 01:34 PM
