engine hesitatiion while on the fly.......
Old Oct 14, 2000 | 04:07 PM
ny96max's Avatar
whenever i drive my 96 on the highway and punch it the engine seems to cut out. It feel like maybe it could be a fuel injector or pump. Its like the engine cuts out and bucks a bit then keeps goin... even has a weird boggle when idleing at a light when warmed up!(this happens every 2min or so) Its definitly not the tranny cause i had that checked out. Any of you guys have any suggestions to what this might be?
Old Oct 14, 2000 | 07:32 PM
Daniel B. Martin's Avatar
How many miles are on your Max? Perhaps the Oxygen Sensors are getting "tired".
Old Oct 15, 2000 | 03:20 PM
ny96max's Avatar
i just hit 60k and did the complete tune up
PCV, Fuel Filter, NGK plugs, OIL/OIl filter and ALL 3 of the o2 sensors... I still dont know what it could be!
Old Oct 15, 2000 | 05:07 PM
mzmtg's Avatar
Minister of Silly Walks
Clean the fuel injectors
nm
Old Oct 15, 2000 | 05:25 PM
Check the fuel pressure
Install a T-fitting with a pressure gauge in the flexible rubber fuel
line just downstream of the fuel filter. You should see the pressure jump
to something like 30 psi within one second after turning the ignition to ON.
After turning the engine off the fuel system should hold pressure for a long
time, 24 hours or longer. If the residual pressure bleeds off in only two
or three hours that is a sign of a problem... bad fuel pump check valve,
injectors with an internal leak, or an external fuel leak.
Old Oct 15, 2000 | 09:09 PM
Matt_P
That is exactly what I am experiencings - almost
except, I have a 5sp and a supercharger. The first buck is at about 3700rpms and another at 4300rpms. My fuel pressue gauge should be in at the end of this week.
Matt P.
Old Oct 16, 2000 | 03:20 PM
ny96max's Avatar
Re: Check the fuel pressure
where can i get a fuel pressure tester?? Will this narrow it down to the pump or the injectors?? How can i narrow it down to either? i ran this STP Fuel Injectors cleaner and i kinda helped for like a week then the problem came back!!
Old Oct 16, 2000 | 04:24 PM
adam714's Avatar
how do you clean the injectors
Old Oct 16, 2000 | 07:30 PM
Please replace your fuel filter. Buy three cans of
name-brand fuel injector cleaner and treat three successive tankfuls of
gasoline. I've had good results with this kind of "snake oil" remedy.
Old Oct 16, 2000 | 08:30 PM
Re: Re: Check the fuel pressure
You can buy a professional test kit such as K-D Tools #3467, list price $343. You can do what I did, which is cobble together a perfectly good equivalent. Buy:
- 4 brass hose barbs, 5/16" x 1/4" pipe thread
- 1 brass T fitting, 1/4" pipe thread
- 1 pressure gauge, 0 - 60 psi
- some teflon tape or pipe thread sealer compound
All of these items can be obtained at a home improvement store (Home Depot or equivalent). A plumbing supply shop should also have these items.
You will also need:
- a short length of 5/16" high-pressure fuel line
- 4 5/16" hose clamps
These items can be obtained at an auto parts store. Everything necessary should cost less than US$20.
I once installed this rig on a Stanza to help diagnose a driveability problem, and liked it so well that I left it in place as permanent instrumentation. Makes me wish that Nissan would install a fuel rail pressure gauge at the factory.
Will this narrow it down to the pump or the injectors ??
No, because I can't guarantee your problem is caused by the pump or the injectors. However, measuring fuel pressure is a routine and useful diagnostic procedure. You can pay the dealer to do it, or you can do it yourself.
That is a good indication that your problem is related to fuel rather than ignition or vacuum or sensors or the computer... I have had good luck with fuel injector cleaner but it may require treating three successive tankfuls of fuel to achieve lasting results.
Old Oct 17, 2000 | 05:30 AM
adam714's Avatar
Daniel...
do you recommend a particular brand of injector cleaner?
Old Oct 17, 2000 | 06:20 AM
Black VQ's Avatar
Could be the tranny...
Happens with my '99 auto too. It's called 'downshifting.' Just my first guess, k?
Not trying to be a smart-aleck or anything, but that will happen with almost any automatic car. When you drive a 5spd, and you're already traveling at hwy speed and need a little boost, whadda you do? You downshift to get the revs up, then upshift again so that you're higher in the gear/engine sweet spot. Auto trannys do it too, just a bit slower than you might be able to do yourself.
Old Oct 17, 2000 | 07:49 AM
Re: Daniel...
No. I recommend any name-brand product. I think they are all pretty much the same. The ingredient lists cite "petroleum distillates". That's not very informative, since jet fuel, gasoline, kerosene, motor oil, diesel fuel, and home heating oil could all be described the same way.
Old Oct 17, 2000 | 08:52 AM
ny96max's Avatar
NOT the tranny...
Im gonna try the Techron Fuel Injector cleaner with 3 tanks of gas like Daniel B. Martin sugested (mechanic)!
Hey bro thanks for your input about my problem. A local shop that is a good friend of the family told me it would cost me $40 for them to slap on a fuel pressure gauge to test my lines. I will let you know the results wehn i get them.
lata!
MAXIMA MEET SATURDAY NOVEMBER 11TH
NATICK, MASS.
(check the general discussion page)
for more info.
Old Oct 17, 2000 | 09:17 AM
Re: NOT the tranny...
... A local shop that is a good friend of the family told me it would cost me $40 for them to slap on a fuel pressure gauge to test my lines. ...
Consider buying the gauge and fittings listed in a previous posting and having this shop install it as a permanent item of instrumentation. The parts might cost you $20 but the shop's labor charge should be lower because they would install it and leave it, rather than install their own tester, make readings, and then remove it.
An advantage of having the permanent installation is that you are better able to diagnose nasty intermittent problems. If you have the shop make measurements with their tester, that tells you about your fuel pressure today. If your engine misbehaves next month, you could
- spend another $40 for another shop test, ... or ...
- raise your hood and read the gauge.
Old Oct 17, 2000 | 02:14 PM
Ryan93SE's Avatar
ny96maxse....can you post some pics of your car....
i am thinking about getting a 95se and i have monsoons and i was wondering what it looks like...thanks
James92SE
142
Jan 2, 2024 09:23 AM
homewrecker
Sep 24, 2015 07:01 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
