KYB OEM Strut Mount+Bearing??
Old Mar 30, 2006 | 01:47 PM
Jamaha80
I got my strut mounting kit which includes the bearing.. If anyone has seen these.. Why is the bearing they include made out of plastic?? Its just two peices of plastic put together forming a "ring" one peice is inside the other and it turns like a bearing should, but if my old REAL bearings are still functional, should i just regrease them and use them instead of this shady looking one?? I dont think the old bearing will work with the new KYB mount though.. Anyone have experience with what im talking about?
Old Mar 30, 2006 | 02:45 PM
BEJAY1's Avatar
Conecarver
The OEM strut mount bearings are plastic (or poly something). What "REAL" bearings are you talking about? Could you explain or post a picture?
Old Mar 30, 2006 | 08:46 PM
Jamaha80
Well in my Haynes manual on page 10-6, the bearing that is shown in the strut mount looks something like this:
More like a ball bearing.
As opposed to this:
Which is what was sent to me with the strut mount.
This is the mount that the bearing came with:
Old Mar 30, 2006 | 10:25 PM
aussie983's Avatar
this should help you out:
http://www.motorvate.ca/mvp.php/703
Old Mar 31, 2006 | 05:02 AM
BEJAY1's Avatar
Conecarver
I've never seen a bearing in the OEM struts like that either. Part#4 on this diagram is the OEM bearing that aussie983 posted about.
http://forums.maxima.org/showpost.ph...93&postcount=6
Old Mar 31, 2006 | 05:17 AM
JwaxMax99's Avatar
Don't worry, you have the correct part. That steel bearing is not from your car. You are good to go.
Old Mar 31, 2006 | 05:24 AM
DragonMaxima's Avatar
Plastic bearings look normal to me.
Old Mar 31, 2006 | 07:06 AM
Jamaha80
Thanks for the help, what a relief!
Old Mar 31, 2006 | 07:15 AM
Jamaha80
But where do I put the grease? Do I take appart the bearing and put it inside? Will wheel bearing/axle grease do the job??
Old Mar 31, 2006 | 09:20 AM
Jamaha80
Bump please! Going to be working on this tonight or tomorrow! Thanks
Old Mar 31, 2006 | 09:45 AM
DAVE Sz's Avatar
Hooooooonda.....
what grease? They already have green grease inside them.
Old Mar 31, 2006 | 10:59 AM
Jamaha80
Thanks!
knight_yyz
Nov 1, 2015 01:34 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
