glue for bodykit
Old Mar 30, 2006 | 03:17 PM
Litowcas's Avatar
glue for bodykit
i need some kind of glue to hold my ionic dynamics rear valances in place.... i tried the bonding tape but its just too wide and shows through the crack... also the pieces are a lil "crooked" so if u try to screw them under the car first, huge gap apears on the front...so im thinking getting some kind of glue to put it on and let it dry over night and then just screw the screws in as a safety measure, ppl at autozone didnt know what i was taking about and just kept pointing at m3 tape.... anybody knows which glue should get the job done?
Old Mar 30, 2006 | 03:44 PM
99grnmaxgxe's Avatar
So you tried the doublesided tape already? It's pretty thin....
Old Mar 30, 2006 | 03:48 PM
Litowcas's Avatar
yes i did
Old Mar 30, 2006 | 04:17 PM
BlackMaxdout's Avatar
well, if you don't ever want it coming off again, you could try some medium/quick set epoxy. Just make sure you clamp the valance on good while it is drying.
Old Mar 30, 2006 | 07:29 PM
NYC32798's Avatar
Gorilla glue maybe? But I think that would also be a permanent fix.
Old Mar 30, 2006 | 08:21 PM
that would work, but it needs moisture to cure right...so it would be weird trying to use it. Plus it expands and gets all over the place.
Old Mar 31, 2006 | 07:30 AM
North's Avatar
construction adhiesive, or clear caulk maybe what your looking for......
Old Mar 31, 2006 | 08:41 AM
Tim96I30t's Avatar
I would use a bead of silicone or caulk, something that you can use in the caulk gun so you can get an even straight bead of glue.
Old Apr 2, 2006 | 10:54 PM
cleanmax's Avatar
there are a few types of double sided tape for body work one is red and the other is white.(not white with green stipes on the other side just solid white.) autozone had the red and you can ask any body shop for the white, they should give you some. White is the stongest. Anyway you have to some what heat the tape up when you get it one the car with a blow dryer not a heat gun that gets to hot and if your not careful you will melt your kit. Glues are ok but if you want it done right you should use the white body tape and make sure that when you put it on heat it up so that way it adhears beater and make sure the area is clean of any dirt. You could even rivet them in.
Old Apr 2, 2006 | 11:13 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Does no one use screws anymore?
Old Apr 2, 2006 | 11:21 PM
maxima_kenny96's Avatar
epoxy/apoxy is like a weld only glue, it'll never come off try that.
Old Apr 3, 2006 | 09:18 AM
ManualMaxima's Avatar
5th Gen till she dies!
use pop rivets not screws like cleanmax said
msellas
Sep 23, 2015 09:16 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
