Replacement for Resonator
Old Apr 1, 2006 | 11:32 PM
Scooobay's Avatar
allegidly ( according to meineke ) my resontor needs to be replaced...instead of paying 145 for the part i found this on ebay, will this work for me?
http://cgi.ebay.com/ebaymotors/Stain...spagenameZWDVW
Old Apr 2, 2006 | 12:25 AM
__Kevin__'s Avatar
That part you've shown replaces the Cat. I'm pretty sure you could find a Resonator for cheaper than 145 bucks though.
Old Apr 2, 2006 | 03:27 AM
huyqvu's Avatar
for roughly 100bux u can get a oem bpipe with a resonator on it and install it yourself. you can get it from any of the nissan parts website. they list it as a front muffler.
Old Apr 2, 2006 | 04:38 AM
mad-max98's Avatar
this is no resonator it's more like the straight pipes i replaced the cat with no resonation what so ever
Old Apr 4, 2006 | 11:15 AM
maxima1380's Avatar
when I got my exhaust put on I had the cut the resonator off and custom make a pipe. That was 2 years ago and my car has been fine. It cost $25 extra for the custom pipe, and Meineke did it.
Old May 3, 2006 | 04:56 PM
AlpineGt66's Avatar
do it yourself and you will feel the power in yourself!
Old May 3, 2006 | 06:13 PM
Gismo-T's Avatar
B!tch We Got a Problem
when you replace the resonator w/custom pipe, is there any difference in sound??? I believe it would be louder, but how much w/stock exhaust?
Old May 4, 2006 | 11:07 AM
alcatranz518's Avatar
It depends on the rest of your exhaust system. I had it taken off while I still had the rest of the factory exhaust on and it had a perfect tone. But after I installed a high flow cat and Warpspeed y-pipe, I reinstalled the resonator (or b-pipe) because it had a raspy, bumblebee type of sound mainly around 1500-2500rpms (similar to any GM 6 cylinder- i.e. pontiac GTP or bonneville-you know the hidious sound I speak of I assume). But just removing it added freed up no power whatsoever. Actually, when i had it reinstalled after the ypipe and cat, I noticed I had more bottom end/ off the line power. Probably because of needed backpressure.
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
