Rear shocks removal??
Old Apr 2, 2006 | 04:16 PM
Jamaha80
Does anyone know of a DIY article for the rear struts/shocks? All I see is for the fronts, such as what is found in the haynes manual. Basicaly wht Im looking for is, where are the top bolts located for the rear struts to remove them? Do I need to take the carpet out of the trunk to get to them? Thanks.
Old Apr 2, 2006 | 04:23 PM
jwmaxse's Avatar
You guessed right. You just peel back the carpet/molded plastic stuff in the trunk above where the strut goes and there's three bolts.
I'm feeling nice today so I'll give you a link to autozone's online manual:
http://www.autozone.com/servlet/UiBr...3d801f56e1.jsp
I'd feel really bad if you got killed by a spring so there's the instructions you need.
Old Apr 2, 2006 | 04:24 PM
black97's Avatar
Simply tear out your quarter panel covers in the trunk there should be 3 or 4 plastic clips on each side
Old Apr 2, 2006 | 04:25 PM
Fr33way™'s Avatar
Wild for Width
Yes, the truck lining that is clipped in with plastic fasteners. Keep them in a small little container there are quite a few. Once you remove the lining, you will now see three bolts on each side. The MIDDLE bolt (top hat nut) on each side is part of the STRUT ITSELF. You do not need to mess with this unless you are taking the springs off the struts. The two bolts on each side (that go into the strut tower) are the ones you want to loosen.
If you take these off, you want to support the assembly with your free hand when removing the lower mounting bolt. (with the car in the air)
After you take that out you simply drop the assembly out of the strut tower.
Old Apr 2, 2006 | 04:30 PM
Jamaha80
wow, thanks for all of your prompt replies..
Old Apr 2, 2006 | 04:32 PM
Jamaha80
I'll be doing them this weekend since the brown truck guy got lost.. If anyone would like a DIY w/pics, let me know and ill document it.
Old Apr 2, 2006 | 05:17 PM
Fr33way™'s Avatar
Wild for Width
I suppose it wouldn't hurt, but there is a good one in the 5th gen stickies.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
