dead battery after 2days???
Old Apr 5, 2006 | 03:05 PM
nfo184's Avatar
for some reason my car is dead on me when i try to start it after more than 4days :-( brand new optima battery too....i have tvs and neons and a alarm system and and subs and all but all turned off ....does it draw on the battery even tho the cars and all the switches are off???? is something sucking my brand new battery dry???
Old Apr 7, 2006 | 10:12 PM
fociis's Avatar
First try checking for a parasitic charge. If you can't find one then check your alternator. You can have it tested at AutoZone for free.
Old Apr 7, 2006 | 10:21 PM
99grnmaxgxe's Avatar
Yeah, I would check out the alternator.
Old Apr 7, 2006 | 10:44 PM
D-Bo's Avatar
Droppin logs
to the alternator.
Old Apr 8, 2006 | 04:57 AM
njmaxseltd's Avatar
Originally Posted by nfo184
i have tvs and neons and a alarm system and and subs .............. is something sucking my brand new battery dry???
Check your electronic equipment, something isn't turning off all the way.
If it's anly going dead while sitting, it's definately not your alternator.
Old Apr 12, 2006 | 12:08 PM
nfo184's Avatar
all i have running is a little power pack voltage charger ...but its only a small led and i dont think it draws that much.....could my amp or capacitor be pulling power while off?
Old Apr 12, 2006 | 12:20 PM
TurTLe*'s Avatar
with all your aftermarket electrical stuff anything would be drawing power. Maybe drawing it while its off. Something could be on stand-by mode but not actually be off.
best way to test this is remove your postive terminal off. get an AMP meter, have 1 end touch the battery terminal and another end touch the postive cable. turn everything off on your car and see how many amps its currently drawing. generally a car could have about maybe .5 amp of draw with the car completely off. But if you noticed anything high then you need to start looking for where the draw is.
A draw from a glove box light being on constantly is enough to drain a battery within 3 days.
Old Apr 12, 2006 | 12:35 PM
bhunter's Avatar
Anything is possible. Disconnect your postive terminal and hook an ammeter in series with the wire and the battery. See what kind of draw you have. If it is more than a few milliamps start unhooking things and see what causes the draw to change.
If there isn't much amp draw then use the voltage function of the meter to check out the charging of the alternator
Old Apr 12, 2006 | 12:42 PM
Swazey's Avatar
make sure your head unit is completely off when ur key is out of the ignition. i had the same problem with my battery going dead after 2 days.
my headunit somehow would stay on. not completely on, but not completely off. since it wasnt turned off, juice was still flowing to the headunit and the amp, killing the battery. i just reset the headunit and it was fixed.
good luck!
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
