When I turn the Steering WHeel I hear Groaning/ growling!
Old Apr 6, 2006 | 01:13 PM
1995WhiteMaxima's Avatar
I had my front axle replaced months ago after it snapped. Now, I suddenly have this groaning every time I turn the wheel in either direction. I haven't checked the axle again yet, but the PS fluid level seems fine. What could it be?
Old Apr 6, 2006 | 01:14 PM
Dooley's Avatar
PS unit.....
Old Apr 6, 2006 | 01:37 PM
clive's Avatar
100% chingon
Could be the rack or it could be the pump.
You ARE using the correct fluid? Check your handbook.
Old Apr 6, 2006 | 05:17 PM
knight71's Avatar
This could possibly be bad strut bearings..Check this link:
http://www.motorvate.ca/mvp.php/703
Old Apr 6, 2006 | 07:49 PM
goldmax's Avatar
Don't use PS fluid....use Dexron III like the manual says. PS fluid will make it groan at the far limits.
Old Apr 11, 2006 | 05:16 AM
I changed the PS fluid Dexron II several months ago. THe sound is kinda sudden.
Old Apr 12, 2006 | 12:03 PM
EdgeVetto's Avatar
I had a volvo 940 that I beat to hell, and it developed a noise like that during a move I like to call the "volvo wobble." It was losing PS fluid slowly. I just refilled it and everything was fine.
Old Apr 12, 2006 | 12:20 PM
russianguy's Avatar
i got the same prob please help>>>>
Old Apr 12, 2006 | 06:20 PM
diy_dreamer's Avatar
When you turn the wheel all the way to one side and hold it, does the groan continue or stop?
Old Apr 12, 2006 | 06:24 PM
wannaboostbad's Avatar
HELL YEAH I GOT THAT PROBLEM TOO!!!!!, got both axles replaced in the past........10 months, passenger side is BRAND new like last week the groan is somewhat annoying if i dont have my music on, but egh........... unless i can get a "quick" fix for really cheap i'm not worried cuz i'll sell it and get an IS300 this fall anyway.
Old Apr 17, 2006 | 08:24 AM
i turn the wheel and if i hold it, it stops. The noise only occurs when i turn the wheel. I dun get it, both axles were replaced!!!
Old Apr 17, 2006 | 09:40 AM
Jesse729's Avatar
Ive always thought this problem is normal when I turn the wheel to the far left or right. It's just the sound of the power steering pump. Ive noticed on larger cars, like cadillacs the sound is much louder because they have massive power steering pumps.
Old Apr 17, 2006 | 12:24 PM
runyun972's Avatar
i'd double check all your rubber bushings and ball joints
Old Apr 17, 2006 | 12:29 PM
1996blackmax's Avatar
So it does this when it's stopped, or moving?
If it does it while moving, it may be you wheel bearing going out.
Old Apr 17, 2006 | 05:00 PM
docroadrage's Avatar
Check the boot... there may be a slight tear. Also inspect your belts... they may be bad
Old Apr 17, 2006 | 07:34 PM
maximaman10's Avatar
Did you replace the wheel bearings too or not?
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
tnewbs
Aug 28, 2015 10:15 AM
jhontelj
Aug 17, 2015 04:07 AM
Flores94
Aug 11, 2015 12:53 PM
