where can i get parts to build my motor
Apr 6, 2006 | 08:27 PM
well i think the title speaks for itself. and what kind of parts would i need to get?
*edit* oh and what parts go in to building a motor besides pistons, and rods. i mean like a total build.
Apr 6, 2006 | 08:32 PM
i think you should search the all motor section first, google the parts your interested in, also are you building it for NA purposes or for boost? I would google "vq30de (pistons, rods, etc)" and see what comes up.
Apr 6, 2006 | 08:34 PM
Quote: i think you should search the all motor section first, google the parts your interested in, also are you building it for NA purposes or for boost? I would google "vq30de (pistons, rods, etc)" and see what comes up.
thanks, i really wasnt sure what to look for.
Apr 6, 2006 | 08:42 PM
http://www.importperformanceparts.ne...ek-nissan.html
Apr 6, 2006 | 09:08 PM
You can also get some from the 4th Gen Classifieds.
Quote:
Nissan Maxima 2988cc 24v DOHC V6 1992-99
Engine
Code Stock
Bore Includes: Kit #/Price
VE30DE (92-94)
VQ30DE (95-99) 93mm Complete Gasket Set
Copper Performance Head Gasket
ROSS/Wiseco Forged Performance Pistons
(93, 94mm bore) and
(9-1, 10-1, 10.5-1 comp ratio)
Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers (95-99 only)
Freeze Plugs EKD33MPX (92-94)
EKD34MPX (95-99)
$1199
Following Kits w/TOGA HV Oil Pump
EKD34MPXG (95-99)
$1300
Call to Order!
(603) 378-0090
That's a lot of money for a little hp.
Apr 6, 2006 | 09:14 PM
Quote: That's a lot of money for a little hp.
that is tru, but its better in the long run, and at higher RPM's than the stock stuff.
Apr 6, 2006 | 10:40 PM
Quote: that is tru, but its better in the long run, and at higher RPM's than the stock stuff.
I can appreciate their use in specific setups but you do have to weigh their value in relation to what you want to achieve.
Here's a spoonful for teh n00bs...
http://www.jimwolftechnology.com/cus...gory=&offset=0
Apr 7, 2006 | 12:23 AM
honestly if you have to ask, let a shop build it.
Apr 7, 2006 | 02:13 AM
unless you're constantly beating on the engine or running high boost, a well maintained VQ30 should be more than enough engine.
Apr 7, 2006 | 07:12 AM
Quote: unless you're constantly beating on the engine or running high boost, a well maintained VQ30 should be more than enough engine.
WORD WORD...even still there are many stock blocked/internaled vq30s runngin high boost and getting beat on with no problems
Apr 8, 2006 | 02:18 PM
how much power gain do you think you will get if you used that import performance #19 w/ 10.5 to 1 comp. ratio?
Apr 8, 2006 | 02:21 PM
Quote: WORD WORD...even still there are many stock blocked/internaled vq30s runngin high boost and getting beat on with no problems
i suppose that's true as well. unless something is already busted, it may be worth it to replace with an upgrade, but if the stock block is just fine, if it aint broke, don't fix it. stock VQ should be just fine. many testimonials on here.
Apr 8, 2006 | 03:17 PM
obligatory suggestion I forgot to offer previously
Donate & Search...
