5spd swap reliability
Old Apr 6, 2006 | 08:39 PM
One Crazy Max's Avatar
i was curious to how reliable the 5 spd swap is after it is done. ive heard stories that the car doesnt run the same way it was, which indeed is tru because its a manual. but i just want to know the downsides to the 5 spd swap.
Old Apr 6, 2006 | 08:42 PM
nismology's Avatar
And you posted this in the all motor forum because......??
Old Apr 6, 2006 | 08:43 PM
well i saw alot of other threads on 5spd swaps in here, so i thought i would post it in here. is that a problem?
Old Apr 6, 2006 | 08:46 PM
nismology's Avatar
Your question is general in nature, so it should go into the general 4th generation forum.
Old Apr 6, 2006 | 08:48 PM
ok. should i post it there or will someone move it?????
and do you have any answers to the question that would be helpful?
Old Apr 6, 2006 | 08:53 PM
nismology's Avatar
Probably not...
The problem is i don't even know what you're asking. A local .orger completed a 5-speed swap recently and his car works just fine.
konak85's Avatar
you can ask tavarish, he's done the swap.
Old Apr 6, 2006 | 09:09 PM
aznsap's Avatar
i've done the swap. a friend of mine also (nismo3112). we're both still running strong and if you do it right, there shouldn't be anything wrong with it.
Old Apr 6, 2006 | 09:15 PM
tavarish's Avatar
fwd gone rwd cr00
It's true, my car never ran the same after the swap. It ran alot better.
the swap is as reliable as the parts and effort you put into it.
Old Apr 6, 2006 | 10:23 PM
i was talking to my uncle about it, and he said that something had to be changed like in the intake manifold area, i cant remember.
is it possible for someone to name the MAIN PARTS that have to be swapped for the car to run properly.
Old Apr 6, 2006 | 10:29 PM
Nismo3112's Avatar
Custom User Title
It is possible... because the parts list is a sticky in this forum.....
Old Apr 8, 2006 | 05:58 PM
tavarish's Avatar
fwd gone rwd cr00
definitely possible.
here's the parts you NEED.
clutch pedal
clutch master and slave cylinders and lines.
5spd tranny
flywheel
clutch
driver's side 5spd axle
shifter linkage and shifter
all bolts for above items
Those are the only things you NEED for the swap.
Old Apr 8, 2006 | 08:12 PM
96sleeper's Avatar
best mod I ever did to my maxima.
Old Apr 10, 2006 | 06:14 AM
zazon's Avatar
not to bump the thread... but FYI you don't need the drivers side axle unless you put in the VLSD, this seems to be a common debated topic. you can use the axles from the auto (however since you need to have them out anyway, might as well change them for about 60 bucks a piece)
Old Apr 11, 2006 | 02:31 PM
tavarish's Avatar
fwd gone rwd cr00
auto and 5spd driver's side axles are different. You need the 5spd axle.
Old Apr 12, 2006 | 05:12 AM
zazon's Avatar
hmm my two old ones worked
Old Apr 12, 2006 | 08:38 AM
Nismo3112's Avatar
Custom User Title
So did mine.
Old Apr 12, 2006 | 09:38 AM
tavarish's Avatar
fwd gone rwd cr00
So did mine.
wow, you learn something new everyday.
Old Apr 20, 2006 | 11:29 AM
TJ_Max's Avatar
Paradox Systems Vendor
So do we or do we not need the manual axles? Answer is no. Correct? Saves me time pulling em off and putting em on between my car and the parts car.
Old Apr 20, 2006 | 02:11 PM
darklegend06's Avatar
First of all the 5spd is very realiable. Less parts to break compared to the auto. Oh another thing. Good luck with finding a 5spd they are very rare, unless you are willing to spend for a brand new one.
Edit: I got a quote from my nissan dealer for a 5spd trans brand new. $2000, $2500 + tax is that a good price?
Old Apr 20, 2006 | 02:40 PM
tavarish's Avatar
fwd gone rwd cr00
SMX95 got his tranny brand new for 1800.
Old Apr 20, 2006 | 05:54 PM
dgeesaman's Avatar
Maintenance Monster
If you get it rebuilt before installing it, yes. These trannys seem to need rebuilt every 100-150k.
Old Apr 20, 2006 | 06:47 PM
Blackwind's Avatar
i got my tranny from a donor car that had 140k, it was a 96, the milage on my car at the time of swap was 80k the milage on my car now is 153k the swap was 3 years back. no problems at all. now some of the 95-96 trannys do have problems with the bearings. but having to be rebuilt every 100-150k i dont find that to be correct.
Old Apr 20, 2006 | 07:04 PM
MorpheusZero's Avatar
Yup, 163k here and no probs. 3rd gear synchro is a little sometimes (relaxed 2-3 shift at redline grinds) but other than that it's just fine.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
mkaresh
Mar 12, 2018 06:48 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
