no power to ECU plug
Old Apr 8, 2006 | 12:29 PM
Devchuck2g4's Avatar
Today, I tried to get a private inspection and a print out of the codes that are causing my check engine light to come on. After trying two shops OBD II computers and autozones handheld computer, it appears no power in getting to the plug. I check my 10A Eng Cont. fuse and its good. Has this happened to anyone elses 4th gen? Any way to fix this?
D
Old Apr 8, 2006 | 12:55 PM
pmohr's Avatar
No more Maximas...
Did you have the key turned to Ignition when checking?
Connect a test light between pins 16 and 4 of the OBD-II connector, that'll show truly whether there's no power at the port or there's just no signal getting to the diagnostic computers.
Old Apr 8, 2006 | 01:22 PM
1) Yes the car was tested while the key as in IGN and while started and no luck
2) this connector correct? pin 4 and 16 to determine power
http://www.obdii.com/connector.html
Old Apr 8, 2006 | 01:27 PM
pmohr's Avatar
No more Maximas...
Yep, 16 is +12, and 4 is chassis gnd.
Old Apr 8, 2006 | 02:17 PM
just tested them with a test light and digital multimeter...no power at all!
Old Apr 8, 2006 | 05:18 PM
would there be a way i could swap ecu's with another working one to conclude that mine is bad? also does it jave to be from the same exact year and transmission inorder to work( a 97 auto)? any one with ideas, suggestions would be greatly appreciated.
D
Old Apr 8, 2006 | 05:23 PM
DcMaN's Avatar
i have a 97 auto ecu for sale.
Old Apr 8, 2006 | 06:19 PM
moogotzskillz2's Avatar
my dad had a car at his shop like that, and it turnd out it was the cig. lighter fuse.... So try that??? if yours dont work!!!
-moo
Old Apr 8, 2006 | 07:46 PM
just bought a pack of mini fuses and replaced all fuses! no luck..I did some searching a while back on the forums and someone said it could be the ECCS relay under the hood. Anyone know how to go about testing relays?
D
Old Apr 9, 2006 | 09:02 AM
..i also tried leaving the battery disconnected overnight and tried again this morning and no luck.
anyone have any other suggestions?
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
sdotcarter
Sep 2, 2015 09:53 PM
