Does not beep when lights on and engine off!
Old Apr 10, 2006 | 11:30 AM
jayanth's Avatar
Countrymen,
Just bought a 97SE, discovered this problem.The door open indicator in the gauge cluster does not work, the car does not beep when the lights are on and the car is turned off,the car locks even if the key is in the ignition switch.This is wierd!My 95 GXE was just the opposite and behaved normally.Looks like thay're all related to a fuse/relay.Has anybody come across this problem?
thanks,
Jay
Old Apr 10, 2006 | 11:41 AM
MDeezy's Avatar
the device is located under the steering wheel, that plastic piece that covers under the steering wheel. Remove that piece and you'll see the device, stuck to the plastic, either its unplugged, or you need a new one. Either way very easy and innexpensive fix.
Old Apr 10, 2006 | 02:12 PM
JNCoRacer's Avatar
Just the tip.
Do the courtesy lights on the doors come on when the door opens? Also, if you lock the car with the keys in the ignition is the door open then? I had a similar problem that was caused by the push switch on the bottom of the door jam. Thats another thing you could check. Cheap and easy too...just like the moms of most the members here. Hahaha. j/k
Old Apr 10, 2006 | 03:32 PM
XeroX's Avatar
Hella internets
I unplugged that little box under the stearing wheel cause i HATE the beaping...fuggin anoying if you ask me....
However, doing this does NOTHING but remove the noises made by leaving the lights on or having the door open with the key in the ignition...
Like mentioned above i believe its a problem with the switch on the door jam...
my .02
scutmud
Aug 16, 2018 10:56 AM
vingodine
45
May 21, 2016 12:46 PM
bc992164
Aug 26, 2015 12:19 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
