Clutch issues <---- Need Help!
Old Apr 11, 2006 | 06:33 AM
PatDezNuts's Avatar
Well I got in my car this morning and when I went to go push the clutch pedal in it fell to the floor. I expect that the clutch slave cylinder is malfunction, but what should I expect to pay if I get this replaced? Also I can tell that the clutch is on its way to needing to be replaced, does anybody know of any good sites where I could pick one up. There used to be a good site on here of the different clutches you could get for a max and what sites to get them on but I can't seem to locate it. Any info on what clutches are good and where to get them would be much appreciated. Thanks.
Old Apr 11, 2006 | 08:06 AM
cardana24's Avatar
Blown
its probably you slave cyliner or else a hole in the hose going to it. I am guessing if you look in your clutch resivior on the fire wall (in the driver side corner) it will be dry. i had the same problem. I replaced the slave cylinder and hose and everything was good to go after I blead the system. If you just need to limp around until you have time to fix it just fill up the resivior with DOT3 and then bleed the system, and keep a close eye on it, also you can try to pin point the leak one you have fluid in the system.
I think requin6 is selling a new 4th gen slave cylinder, you should check with him if you decide to go this route.
Old Apr 11, 2006 | 09:22 AM
Maximus_95's Avatar
check if you are full on the clutch fluid. if you are empty, fill it up and that should fix the problem. now....if you are full, you are expecting about $100-$150 dollars to fix the problem. (Slave that is) Good luck.
Old Apr 11, 2006 | 10:06 AM
cardana24's Avatar
Blown
Filling it up will not fix the problem. DOT3 does not evaporate, so if you are low on fluid then you have a leak. Filling it up and bleeding the system will allow you to get around until you can fix the problem, but you are only delaying a fix, not actually fixing anything. As for replacing the slave, it's very easy, its only a few bolts, IMO you should not pay anyone to do this, its too easy and you may learn something too.
Old Apr 11, 2006 | 10:35 AM
95bluse's Avatar
A couple of years ago I replaced my leaky clutch hose & bled the system from both the slave nipple & the top one on the strut tower. I've had to go back & bleed it a couple of times, but I only did the top one because it was easier. It seems like air is getting in either in the master or slave cylinder. The symptoms:
If I keep the clutch depressed for a length of time..say at a traffic light, it will start releasing lower...almost causing the car to creep forward. If I release it in neutral & pump it a couple of times. it's fine. Question is, since I've only bled the slave once (just after changing the hose), should I do that again? I don't want to change the slave and then find out it's the master cylinder...how do I figure out which is leaking?
I didn't want to hijack this thread but I think it relates, since the original poster may encounter the same issue.
Old Apr 11, 2006 | 02:36 PM
dgeesaman's Avatar
Maintenance Monster
It's probably best to replace both the master and slave. Reason being, when one fails the other usually follows soon after. Price is probably $250 in parts and $100 in labor.
Dave
Old Apr 11, 2006 | 04:22 PM
ManualMaxima's Avatar
5th Gen till she dies!
yea try bleeding it, mine did this and it was my master cylinder......i replaced my slave and that was not the problem. try to bleed it/
Old Apr 11, 2006 | 04:56 PM
Maximus_95's Avatar
what im trying to say is that if he was empty on the fluid to begin with, it might be that.
but if its not that, then its the slave...duh........
Old Apr 12, 2006 | 10:45 AM
95bluse's Avatar
Thx for the input..I think it's the master cylinder since there always is air in the upper pipe which is connected to the master cylinder. I'll try bleeding at the slave again since I have nothing to lose.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
conansriver
Nov 18, 2015 02:46 PM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
